How to get write permission?
Learn about scoring Download Discussion's Raw Score: 330095.0
May 18, 2010 02:33 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Pablo
Member
Hi, Samba works just fine, thanks.
But how can I get write permission on my share?
Discussion:    Add a Comment | Comments 1-12 of 12 | Latest Comment
May 18, 2010 3:11 PM
If you use Public Share, set "Readonly" to "disabled".
Then if you don't use win explorer or konqueror you may have to set a user,password for example using an fstab entry:
//192.168.0.1/Public /mnt/net cifs username=guest,password=guest
Windows Explorer, Konqueror etc. automatically submit a standard user which will then be mapped by samba to a guest user. In this case you don't have to do anything. I don't know if macs do this to.
May 20, 2010 4:21 PM
Kong said: If you use Public Share, set "Readonly" to "disabled". Then if you don't use win explorer or konqueror you may have to set a user,password for example using an fstab entry: //192.168.0.1/Public /mnt/net cifs username=guest,password=guest Windows Explorer, Konqueror etc. automatically submit a standard user which will then be mapped by samba to a guest user. In this case you don't have to do anything. I don't know if macs do this to.
No succes.
I think it's a windows xp problem.
When I connect using telnet I get this information:
root@WRT3500L:~# mount
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro)
none on /dev type devfs (rw)
proc on /proc type proc (rw)
ramfs on /tmp type ramfs (rw)
sysfs on /sys type sysfs (rw)
devpts on /dev/pts type devpts (rw)
devpts on /proc/bus/usb type usbfs (rw)
/dev/mtdblock/4 on /jffs type jffs2 (rw)
/dev/discs/disc0/part1 on /jffs type vfat (rw,fmask=0022,dmask=0022,codepage=cp437,iocharset=iso8859-)
root@WRT3500L:~#
Can someone help me out?
May 20, 2010 6:54 PM
Ah okay, now I can see it, the problem is that the partition is mounted with fmask=0022,dmask=0022, therefore only root has write permissions, but samba will access as either guest user or the user you specified.
DD-WRT should mount fat partitions with umask=0000, that's the problem. Until this has been changed you could do the following:
Go to Services->NAS->FileSharing
Disable Public Share, check Use Custom Configuration, then add in Custom Configuration:
[global]
server string = 3500L
workgroup = Home
interfaces = br*
bind interfaces only = Yes
map to guest = Bad User
smb passwd file = /var/samba/smbpasswd
private dir = /var/samba
passdb backend = smbpasswd
log file = /var/smbd.log
max log size = 1000
printing = none
load printers = No
usershare allow guests = Yes
[Share]
comment = My Share
path = /jffs/
read only = No
guest ok = No
valid users = root
In User1 field add the user "root" without quotes, supply a password, now connect to your share, with user root+pass. Now samba will access as user root which has write permissions.
May 21, 2010 7:07 PM updated: June 10, 2010 5:46 PM
Updated build 14584 fixes this issue!
June 14, 2010 8:20 PM
Hi
I've just installed the latest build on a rt-n16.
All seems ok, but I also have no write access from Windows 7.
I have Samba public enabled, read only disabled. I formatted my usb drive ext3 assuming this would give better performance(?)
My telnet mount info:
root@DD-WRT:~# mount
/dev/discs/disc0/part1 on /jffs type ext3 (rw,data=ordered)
June 15, 2010 5:43 AM
Hi DiamondView,
just verified this, it is due to the fact, that permissions on /jffs with ext3 only allow writes for root.
As a quick workaround, until it is fixed, you can do the following.
In the Webinterface under Administration->Commands enter:
chmod 777 /jffs
press "Save Startup". After a reboot you will have write access
June 16, 2010 3:25 AM
Hi Kong
Thanks, all good now. Getting about ~5.3 MB/sec read & ~6 MB/sec write transfers from the Samba NAS on the RT-N16 with ext3 usb: how's that compare to the WRT3500?
June 16, 2010 2:05 PM
DiamondView said: Hi Kong Thanks, all good now. Getting about ~5.3 MB/sec read & ~6 MB/sec write transfers from the Samba NAS on the RT-N16 with ext3 usb: how's that compare to the WRT3500?
That's about the same I get with my WNR3500L.
August 14, 2010 11:20 PM
I'm curious to know what USB drive you're using to get 5-6MB/sec transfer rates. I'm getting more like 832KB/sec, at least that's what windows 7 reports.
I'm using an ext3 formatted USB hard drive mounted on /jffs (firmware build 14584). Any suggestions?
August 15, 2010 4:46 PM
I'm using a 8GB USB Stick, not a very fast one. I'll soon have a fast 2,5" drive to create a few benchmarks.
800KB/s is not good:-)
To make sure windows is right, measure the transfered time e.g. 100MB/20s->5MB/s
Don't keep the router busy -> no P2P, other high speed internet traffic
On the router disable any traffic shaping, you could also do a reset to make sure there is no strange setting from previous installs, load usb 2 module, not 1.1
Check using the builtin ftp server, via ftp you should get around 8MB/s write speed
August 15, 2010 5:55 PM
Okay, I reset the router, turned off QoS and disabled USB 1.1 options (just leaving USB 2.0).
I was amazed to see turning QoS off/on alone increased my speed from about 800KB/sec up to 4MB/s. I guess QoS has some real issues, especially considering I supposedly had it set to only adjust WAN traffic.
From what I could tell, the QoS change was the only option that yielded a performance gain though. I wasn't previously using ProFTPD but switched it on for testing purposes. FTP was only marginally faster by about 0.3MB/sec. So at best, my transfer rates now are still only 4.3MB/sec. Even so, that's an amazing increase, thanks! Any other suggestions to attempt to tweak a little more speed out of my setup?
October 9, 2010 10:29 AM
Hi Kong, I was just curious if you ever got that 2.5" drive for benchmarking?
I still can't seem to break the 3.8MB/sec mark myself. That's using a ext3 formatted, 7200rpm, 2.5" hard drive via USB 2.0. I'm pretty much solely talking about SMB type transfers for large files, typically streamed videos to a Boxee PC.
Discussion:    Add a Comment | Back to Top | Comments 1-12 of 12 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
