Problem with usb-hub (05/22/10) stdkong - build 14329
Learn about scoring Download Discussion's Raw Score: 71154.4
June 14, 2010 03:21 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
pepperoni
Member
Mi problem is when the the router boots with a usb-hub the ntfs disk won't be reconized.
If the router boots without the usb hub the ntfs disk it's reconized ok.
If the router boots with the the usb-hub and fat disk it's ok.
Any ideas????
Discussion:    Add a Comment | Comments 1-2 of 2 | Latest Comment
June 14, 2010 5:32 PM
Can you check what happens if you try to mount the ntfs drive connected to the hub manually.
First find the partition using:
dmesg | grep /dev/scsi
you should get a line e.g.: /dev/scsi/host0/bus0/target0/lun0: p1
Now run:
ls -la /dev/scsi/host0/bus0/target0/lun0
The output should display a partition "part1" etc.
After that you can try to mount it:
mkdir /tmp/test
/usr/sbin/ntfs-3g /dev/scsi/host0/bus0/target0/lun0/part1 /tmp/test
Any error messages?
If manual mount works, then I guess it is a timing issue.
June 15, 2010 1:25 PM
Kong said: Can you check what happens if you try to mount the ntfs drive connected to the hub manually. First find the partition using: dmesg | grep /dev/scsi you should get a line e.g.: /dev/scsi/host0/bus0/target0/lun0: p1 Now run: ls -la /dev/scsi/host0/bus0/target0/lun0 The output should display a partition "part1" etc. After that you can try to mount it: mkdir /tmp/test /usr/sbin/ntfs-3g /dev/scsi/host0/bus0/target0/lun0/part1 /tmp/test Any error messages? If manual mount works, then I guess it is a timing issue.
Never mine,
The problem was that no enough power was supplied to the usb hub.
Once I plugged the output  power to the usb hub the disk got reconized.
Thank a lot,
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
