I just upgraded the Kong Mod firmware and retry getting my USB drive connect. I use the default /jffs mount to keep it simple. The drive was recognized, but not mounted. What should I do next? Please help. Thanks.
It has all the information about the hard drive such as disk size, file system, etc... Except at the very end, it said "Status: Not nounted". I tried reboot the router, reset it with no change. Thanks.
--- /dev/discs/disc0/disc
Block device, size 931.5 GiB (1000204886016 bytes)
DOS/MBR partition map
Partition 1: 931.5 GiB (1000202241024 bytes, 1953520002 sectors from 63)
Type 0x07 (HPFS/NTFS)
Windows NTLDR boot loader
NTFS file system
Volume size 931.5 GiB (1000202240512 bytes, 1953520001 sectors)
Status: Not mounted
OK I'll have a look at it. Have you tried to connect this drive to a windows machine and run a full filesystem check?
I did it sometime ago. I can do it again today. What would be the proper way to unmount the drive so that I can remove the drive? Thanks.
For NTFS the proper way right now would be to login kill -HUP all processes that access the drive and umount the drive. I'm adding this to my task list, the best way would be to control this process via the button on the front.
I recently changed the mount point on my Netgear W9R3500L to /mnt instead of the default /jffs, because at some point I couldn't see my files at all.
Hello!
My device has not been actually recognised :(
Under the factory firmware it was working. What should I do to fix?
Please show us the output of:
Services->USB->DiskInfo
also make sure you have my latest build 15758 installed the previous build had a bug which did not display the correct mount status
I rebooted the router and it seems like it has been mounted
Block device, size 3.740 GiB (4016046080 bytes)
Partition 1: 3.736 GiB (4011851776 bytes, 7835648 sectors from 8192)
NTFS file system
Volume size 3.736 GiB (4011851264 bytes, 7835647 sectors)
Status: Mounted on /mnt
How can I see the drive from Windows7?
Hi Pavel,
setup Samba under:
Services->NAS
and set "PATH to Files" to /mnt
set Samba to enable and Public Share to Enable
You may have to disable the homegroup feature as well, see:
http://www.myopenrouter.com/forum/thread/23611/Samba-and-Win-7-with-Kong-Mod/...
Any solution on the first comment (Status: Not mounted)? I have the same problem.
He had an older build that didn't display the correct mount status for NTFS partitions.
P.S.EFI,GPT partitions are not supported
Thank you, Kong! It has been working! One more little question: can I give FTP access to this share?
Kong said: Hi Pavel, setup Samba under: Services->NAS and set "PATH to Files" to /mnt set Samba to enable and Public Share to Enable You may have to disable the homegroup feature as well, see: http://www.myopenrouter.com/forum/thread/23611/Samba-and-Win-7-with-Kong-Mod/...
Yes, if you want access from WAN side (Internet) you have to add a firewall rule, like the one I mentioned here:
http://www.myopenrouter.com/download/discussion/22611/promblem-with-proftpd-w...
I just upgraded from the standard DD-WRT build to the Kong mod in my attempt to set up the DLNA server.
Unfortunately, the router is not recognizing my USB hard drive.
Under Services -> USB I have enabled under USB Support:
Core USB Support
USB 2.0 Support
USB Storage Support
Automatic Drive Mount
The Disk Info section still says "Not Available"
My hard drive is a 500 GB Western Digital MyBook
Can anyone help me to get the router to recognize the drive?
Thank you,
Brandon Young
--Brandon Young
Hi Brandon, read:
http://tips.desipro.de/2010/08/30/usb-drive-not-recognized-wnr3500l/
I upgraded to the latest firmware but my usb drive can not be recognized.
any idea?
here is what I have set:
USB Support
Core USB Support
Enable Disable
USB 1.1 Support (UHCI)
Enable Disable
USB 1.1 Support (OHCI)
Enable Disable
USB 2.0 Support
Enable Disable
USB Printer Support
Enable Disable
USB Storage Support
Enable Disable
Enable Disable
Run-on-mount Script Name
Disk Mount Point
Disk Info
Not available
and here is the information:
root@DD-WRT:~# dmesg | grep usb
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usb usb1: configuration #1 chosen from 1 choice
usb usb2: configuration #1 chosen from 1 choice
usb 1-1: new high speed USB device using ehci_hcd and address 2
usb 1-1: configuration #1 chosen from 1 choice
usb-storage: device found at 2
usb-storage: waiting for device to settle before scanning
usb-storage: device scan complete
root@DD-WRT:~# nvram show | grep usb
usb_automnt=1
usb_ohci=1
usb_storage=1
usb_mntpoint=opt
usb_runonmount=
usb_printer=0
usb_usb2=1
usb_uhci=1
size: 20042 bytes (12726 left)
usb_enable=1
root@DD-WRT:~#
I also am unable to see my disk under Disk Info, i'm using a E3000 with the firmware released on 12/16/2011. Ive rebooted a few times and have followed the formatting recommendations. Here is my DMSG output.
Linux version 2.6.24.111 (bluebat@opensuse) (gcc version 4.1.2) #22 Fri Dec 16 15:32:47 CET 2011
CPU revision is: 00019740
Determined physical RAM map:
memory: 04000000 @ 00000000 (usable)
Entering add_active_range(0, 0, 16384) 0 entries of 256 used
Zone PFN ranges:
Normal 0 -> 16384
HighMem 16384 -> 16384
Movable zone start PFN for each node
early_node_map[1] active PFN ranges
0: 0 -> 16384
On node 0 totalpages: 16384
Normal zone: 0 pages used for memmap
Normal zone: 0 pages reserved
Normal zone: 16384 pages, LIFO batch:3
HighMem zone: 0 pages used for memmap
Movable zone: 0 pages used for memmap
Built 1 zonelists in Zone order. Total pages: 16384
Kernel command line: console=ttyS0,115200 root=1f02 rootfstype=squashfs noinitrd
Primary instruction cache 32kB, physically tagged, 4-way, linesize 32 bytes.
Primary data cache 32kB, 4-way, linesize 32 bytes.
Synthesized TLB refill handler (20 instructions).
Synthesized TLB load handler fastpath (32 instructions).
Synthesized TLB store handler fastpath (32 instructions).
Synthesized TLB modify handler fastpath (31 instructions).
PID hash table entries: 512 (order: 9, 2048 bytes)
CPU: BCM4716 rev 1 at 480 MHz
Using 240.000 MHz high precision timer.
console [ttyS0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 58568k/65536k available (3550k kernel code, 6912k reserved, 1377k data, 216k init, 0k highmem)
Calibrating delay loop... 239.20 BogoMIPS (lpj=1196032)
Generic PHY: Registered new driver
PCI: Using membase 8000000
PCI: Initializing host
PCI: Reset RC
PCI: no core
PCI: Fixing up bus 0
PCI/PCIe coreunit 0 is set to bus 1.
PCI: Fixing up bridge
PCI: Setting latency timer of device 0000:01:00.0 to 64
PCI: Setting latency timer of device 0000:01:00.1 to 64
PCI: Enabling device 0000:01:00.1 (0004 -> 0006)
PCI: Fixing up bus 1
Time: MIPS clocksource has been installed.
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
WRT610Nv2/E3000 GPIO Init
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x1
io scheduler noop registered
io scheduler deadline registered (default)
HDLC line discipline: version $Revision: 4.8 $, maxframe=4096
N_HDLC line discipline registered.
Serial: 8250/16550 driver $Revision: 1.90 $ 4 ports, IRQ sharing disabled
serial8250: ttyS0 at MMIO 0x0 (irq = 8) is a 16550A
PPP Deflate Compression module registered
PPP BSD Compression module registered
MPPE/MPPC encryption/compression module registered
PPPoL2TP kernel driver, V1.0
tun: (C) 1999-2004 Max Krasnyansky
PCI: Setting latency timer of device 0000:00:02.0 to 64
eth0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.100.138.9
PCI: Setting latency timer of device 0000:00:01.0 to 64
PCI: Enabling device 0000:01:01.0 (0000 -> 0002)
PCI: Setting latency timer of device 0000:01:01.0 to 64
Physically mapped flash: Found 1 x16 devices at 0x0 in 8-bit bank. Manufacturer ID 0x0000c2 Chip ID 0x0000cb
Physically mapped flash: Found an alias at 0x800000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1000000 for the chip at 0x0
Physically mapped flash: Found an alias at 0x1800000 for the chip at 0x0
Amd/Fujitsu Extended Query Table at 0x0040
number of CFI chips: 1
cfi_cmdset_0002: Disabling erase-suspend-program due to code brokenness.
Flash device: 0x800000 at 0x1c000000
bootloader size: 262144
nvram size: 61440
Physically mapped flash: Filesystem type: squashfs, size=0x569b71
partition size = 5698560
Creating 5 MTD partitions on "Physically mapped flash":
0x00000000-0x00040000 : "cfe"
0x00040000-0x007f0000 : "linux"
0x001a0c00-0x00710000 : "rootfs"
mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
0x007f0000-0x00800000 : "nvram"
0x00710000-0x007f0000 : "ddwrt"
Found a 0MB serial flash
sflash: found no supported devices
Broadcom Watchdog Timer: 0.07 initialized.
u32 classifier
Actions configured
nf_conntrack version 0.5.0 (1024 buckets, 4096 max)
ctnetlink v0.93: registering with nfnetlink.
IPv4 over IPv4 tunneling driver
GRE over IPv4 tunneling driver
ClusterIP Version 0.8 loaded successfully
TCP bic registered
TCP cubic registered
TCP westwood registered
TCP highspeed registered
TCP hybla registered
TCP htcp registered
TCP vegas registered
TCP scalable registered
Welcome to PF_RING 3.2.1
(C) 2004-06 L.Deri
NET: Registered protocol family 27
PF_RING: bucket length 128 bytes
PF_RING: ring slots 4096
PF_RING: sample rate 1 [1=no sampling]
PF_RING: capture TX No [RX only]
PF_RING: transparent mode Yes
PF_RING initialized correctly.
PF_RING: registered /proc/net/pf_ring/
802.1Q VLAN Support v1.8 Ben Greear
All bugs added by David S. Miller
decode 1f02
Mounted devfs on /dev
Freeing unused kernel memory: 216k freed
roboswitch: Probing device eth0: found a 53115!
USB20H mdio control register : 0x8000000c
PCI: Setting latency timer of device 0000:00:04.1 to 64
ehci_hcd 0000:00:04.1: EHCI Host Controller
ehci_hcd 0000:00:04.1: new USB bus registered, assigned bus number 1
ehci_hcd 0000:00:04.1: irq 5, io mem 0x18004000
ehci_hcd 0000:00:04.1: USB 0.0 started, EHCI 1.00, driver 10 Dec 2004
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
USB Universal Host Controller Interface driver v3.0
ohci_hcd: 2006 August 04 USB 1.1 'Open' Host Controller (OHCI) Driver
PCI: Setting latency timer of device 0000:00:04.0 to 64
ohci_hcd 0000:00:04.0: OHCI Host Controller
ohci_hcd 0000:00:04.0: new USB bus registered, assigned bus number 2
ohci_hcd 0000:00:04.0: irq 5, io mem 0x18009000
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 2 ports detected
SCSI subsystem initialized
usb 2-1: new full speed USB device using ohci_hcd and address 2
Initializing USB Mass Storage driver...
usb 2-1: device descriptor read/64, error -62
usb 2-1: new full speed USB device using ohci_hcd and address 3
usb 2-1: new full speed USB device using ohci_hcd and address 4
usb 2-1: device not accepting address 4, error -62
usb 2-1: new full speed USB device using ohci_hcd and address 5
usb 2-1: device not accepting address 5, error -62
USB Mass Storage support registered.
br0: Dropping NETIF_F_UFO since no NETIF_F_HW_CSUM feature.
device br0 entered promiscuous mode
device vlan1 entered promiscuous mode
device eth0 entered promiscuous mode
device eth1 entered promiscuous mode
device eth2 entered promiscuous mode
br0: port 3(eth2) entering learning state
br0: port 2(eth1) entering learning state
br0: port 1(vlan1) entering learning state
device br0 left promiscuous mode
br0: topology change detected, propagating
br0: port 3(eth2) entering forwarding state
br0: port 2(eth1) entering forwarding state
br0: port 1(vlan1) entering forwarding state
device vlan2 entered promiscuous mode
device vlan2 left promiscuous mode
etherip: Ethernet over IPv4 tunneling driver
IMQ starting with 2 devices...
IMQ driver loaded successfully.
Hooking IMQ before NAT on PREROUTING.
Hooking IMQ after NAT on POSTROUTING.
IPP2P v0.8.2 loading
IMQ driver unloaded successfully.
IPP2P v0.8.2 unloaded
You dmesg output does not look good, seems like the drive is not responding correctly, do you use a self powered usb hub?
WOW ----- The USB drive mounted but I could not "MAP" it in windows. So
turned off HomeGroup in windows 7
and following this thread I went to the
Services -> NAS -> Files Sharing -> Samba -> enable
Created a share using the next part of the SAMBA shares
-> "DATA" as the share name
-> Public = checked
->Access = Read/Write
->Users
-> my PC Login USer Name
-> a password just for this share
->Access Shares = DATA ----> from above in the create share
AND OMG-------- It Works ------
Kong you da Simian (da Man)
Thank you
Can anybody explain the reason of mounted disk drive name change everytime I plug it in and out?
First time it's plugged it names disk0-part1, then disk1-part1, then disk2-part1?
It is so inconvenient to rename it everytime in miniDLNA config.
Maximus said: Can anybody explain the reason of mounted disk drive name change everytime I plug it in and out? First time it's plugged it names disk0-part1, then disk1-part1, then disk2-part1? It is so inconvenient to rename it everytime in miniDLNA config.
This comes from the linux kernel if you don't reboot, can't do anything about it.
But if you want to make sure the partition is always mounted to the same location just set partition labels e.g. label the partition which holds the media files JFFS. After that this partition will always be mounted to /jffs and you can set the dlna path to /jffs/...
Kong, how can I do it?
As far as I understand there are 2 places where partition label can be set:
1) USB settings - where exact label can be associated (but here partition name changes everytime I plug in/out flash drive)
2) DLNA server settings - here I can mention label/path and get rid of permanent renamings. But in your firmware I did not manage to make it work.
In other words - I use following scheme: Flash drive mounts on /tmp/mnt/disk0-part1, after that I write path in DLNA settings to video e.g. /tmp/mnt/disk0-part1/video ("video" folder is created on flash drive) whereas on USB page I leave all fileds blank.
Please explain what should I do in order to free myself up from accessing admin part of my router each time I take out flash drive?
Did you forget your password?
