Need Assistance with USB and Samba
Learn about scoring Download Discussion's Raw Score: 179822.0
November 9, 2010 10:30 PM
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
geah70
Member
I just recently installed build 15510 on my ASUS RT-N16 router.  I attached a 2TB USB HD with 4 partitions and configured SAMBA but can only see a read-only "Public" folder.
The 4 partitions are:
1) Optware ext3
2) SwapFile swapfile
3) JFFS ext3
4) Data ext3
I am expecting to have most of my shared files (documents and media) in the Data partition.  Below is my USB Support screen (note I don't seem to see the ext2/ext3 support)
The Disk Info is as follows:
--- /dev/discs/disc0/disc
Block device, size 1.819 TiB (2000396746752 bytes)
DOS/MBR partition map
Partition 1: 512 MiB (536870912 bytes, 1048576 sectors from 2048)
Type 0x83 (Linux)
Ext3 file system
Volume name "Optware"
UUID CBA2C1CC-A163-49E0-A354-7B71289B767B (DCE, v4)
Volume size 512 MiB (536870912 bytes, 131072 blocks of 4 KiB)
Partition 2: 64 MiB (67108864 bytes, 131072 sectors from 1050624)
Type 0x82 (Linux swap / Solaris)
Linux swap, version 2, subversion 1, 4 KiB pages, little-endian
Swap size 63.99 MiB (67100672 bytes, 16382 pages of 4 KiB)
Partition 3: 256 MiB (268435456 bytes, 524288 sectors from 1181696)
Type 0x83 (Linux)
Ext3 file system
Volume name "JFFS"
UUID A9BA4F14-4574-401F-B0E3-6DD5514DFAA6 (DCE, v4)
Volume size 256 MiB (268435456 bytes, 262144 blocks of 1 KiB)
Partition 4: 1.819 TiB (1999523282944 bytes, 3905318912 sectors from 1705984)
Type 0x83 (Linux)
Ext3 file system
Volume name "Data"
UUID 06E97EAC-FCFA-4782-853F-147997296F56 (DCE, v4)
Volume size 1.819 TiB (1999523282944 bytes, 488164864 blocks of 4 KiB)
Status: Mounted on /opt
Below is the configuration of the NAS.
What am I doing wrong that I can only see a read-only Public folder?
Please note that will also be enabling miniDLNA soon and will point to some folders in the Data partition.  Thank you for help.
Jeffrey
Discussion:    Add a Comment | Comments 1-5 of 5 | Latest Comment
November 10, 2010 1:16 AM
Hi Jeffrey, you have to set Sambas "PATH to Files" to /opt in your case. Ext2/ext3 is not needed anymore, the new hotplug system loads the appropriate fs drivers on demand.
November 10, 2010 8:02 AM
Hi Kong,
Thanks for the quick reply.  I will try that when I get the Samba service working again.  I think I messed it up by installing Optware.  Do you know if your mod is compatiable with Optware?  I believe the Optware package has Samba also included.
Also, I assume that the Samba version is 3 but when I did a verison on it it said version 2.  I thought Windows 7/Vista had authenication issues with Samba versions lower than 3.  I actually attempted to upgrade the Optware Samba to version 3.5 (?) but that didn't work.
November 10, 2010 9:31 AM
The included version is samba 3.0.24. In general it is compatible with optware packages, but some optware packages will not work due to differences in dd-wrt/openwrts toolchain. Once I find the time for it I'll update my ipkg repository again and include the url in the ipkg.conf in the firmware.
November 10, 2010 10:38 PM
Hi Kong
changing the path to /opt worked.  Unfortunately I can only see that partition.  How do I go about mounting the other partitions (especially partition 4)
I attempted to mount part4 to a new directory under /tmp but that doesn't seem to work.  It mounts something but not the part 4
mkdir /tmp/dat
mount /dev/discs/disc0/part4 /tmp/dat
November 11, 2010 6:42 AM
The problem is that /tmp is a readonly dir you cannot create a directory there, you have to use a directory in ram like:
/var/dat
or an existing dir like /mmc /jffs
Discussion:    Add a Comment | Back to Top | Comments 1-5 of 5 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
