Hello
I would be grateful if someone can help/suggest for the below:
I am trying to passively monitor wireless traffic of strongest WAP from a Netgear WNR3500L.
I have flashed the openwrt firmware Kamikaze 8.09.2 on Netgear WNR3500L.
In order to do that:
1- Netgear WNR3500L is wired connected to another router.
2- Have tcpdump installed
The following commands put the Netgear WNR3500L to passive monitor mode.
wl up
wl ap 0
wl disassoc
wl passive 1
wl monitor 1
wl promisc 1
Then perform the scan operation to find the strongest AP and connect on that channel.
Unfortunately the "wl monitor 1" command doesn't create a new interface like "prism0", for the tcpdump to capture the traffic.
It could be that the wirless passive monitor mode is not supported in this beta openwrt firmware build
I would appreciate if anyone can share info about the openwrt firmware build for Netgear WNR3500L, which supports passive wireless monitor mode.
Thanks in advance
-Raghu
wireless passive monitoring doesnt work with Kamikaze 8.09.2
April 9, 2011 4:45 AM
Hey man. I'd like the same thing. Perhaps setting up the WNR3500 like this WRT guide will help? http://www.renderlab.net/projects/wrt54g/openwrt.html
I know it's not as easy as just setting "monitor" mode. you gotta have the right patched wifi-card drivers and a suitable sniffer like kismet (which is definately what you want). You'll be better off following a guide like this. If you already have OpenWRT installed, adding the packages you need should be a piece of cake. I'd help but I use my 3500 for my main router and have a old WRT54G I am going to try for this project.
Good luck.
RSS
