All,
I am using the 18010 build on a WRT610Nv1 router, and am having the folowing issue(s). If anyone has a suggestion to resolve, that would be great.
1. I am trying to set the router as a OpenVPN server. I have all the required cert and am using the GUI to set the TAP configuration. I cannot get the UI to retain the 'Pool End IP'. after entering a valid address, when i click 'save', the field gets blanked out.
2. In setting up a PPTP server, I have noticed that occasionally the 'Server IP' will get blanked out. I have to re-enter the server IP , save/apply the settings to restore functionality.
I am wondering if the two problems are related. I noticed the second problem after repeatedly entering the 'Pool End IP', saving and applying the setting as described in the first problem.
RSS
