Learn about scoring Forum's Raw Score: 4504390.0
January 24, 2008 04:35 PM
Categories: News, Rumors and Gossip Tomato WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Peter Redmer
Administrator
For all of you using the Tomato firmware...
I'm excited for the WGR614L that NETGEAR is releasing soon. It's a Broadcom based router, so it will work with Tomato. So far, I've used DD-WRT, so it will be nice to try out the other options in detail.
Anyone out there using Tomato? How do you like it?
Peter Redmer
Administrator
Blog | Twitter
Discussion:    Add a Comment | Comments 1-19 of 19 | Latest Comment
February 7, 2008 9:56 PM
I have never used Tomato. but have used DD-WRT and Sveasoft. If compatible with DD-Wrt I am really looking forward to it!
http://placeshiftingenthusiasts.com/
February 7, 2008 10:09 PM
Yup, it's going to be compatible with DD-WRT.  Check out this blog entry for more details.  We have hardware and software specs up too!
Peter Redmer
Administrator
Blog | Twitter
February 26, 2008 2:04 AM
So, according to the blog, there's no WPA support with the Tomato firmware? That's a bummer.
I'll wait for the WPA support.
September 12, 2008 9:33 AM
Does the Tomato firmware have to be modified or is it direct from the Polarcloud website?
September 14, 2008 2:35 AM
The tomato version you find here is a modified version.
October 8, 2008 5:58 PM
I just installed Tomato Firmware for WGR614L v1.11.041510 on the WGR614L I just brought home today, about 5 minutes after powering it up, and now I get nothing. It seemed to fail to upload; it went through most of the upgrade progress bar, but then it reported that it "timed out" so I tried to reset the thing to reinstall the default firmware. Now I cannot connect by any means. What can I do now?
October 16, 2008 12:29 AM
YOu just bricked your router. Since it is still new, just return it to the place you purchase it and say it is faulty. :) I suggest returning it and get the Linksys WRT54G Linux as it seems to fully support ddwrt, tomato, and openwrt.
I had sold both my netgear WGR614L as I got tired of waiting for full support of third party firmware.
October 14, 2009 4:37 AM
Does anybody know Netgear router with WPA security, which is running under Tomato ?
Thanks in advance
KC LEE
December 20, 2009 12:59 AM
I have been using the Tomato firmware on a Linksys WRT54GS for over a year - maybe two. The router has been rock solid ever since loading Tomato. Lots of options and I personally think it is easy to configure.
I don't use a lot of the features, but I have used the Access Restriction portion extensively to shut down certain computers or devices at certain times of the day or night. Quite often there are three computers and a X-Box 360 running at the same time and the router plugs right along.
I recently saw the new Netgear router, WNR3500L, being released soon (i hope) that will be able to run tomato. I am excited to make the jump to an "N" router....running Tomato.
December 21, 2009 4:20 AM
Yep darren , the WNR3500L already supports tomato .... You can get the tomato f/w under download section of WNR3500L at this site ...
all d best :)
December 30, 2009 1:58 AM
Except that Tomato doznt support N!
December 31, 2009 12:27 AM
The wireless mode is dependent on the wireless driver which is by default N for WNR3500L .. so by default it will operate in N mode only ....
But there is no GUI option in Tomato f/w using which u can change the wireless mode ...
January 10, 2010 9:50 AM
I recently bought a WGR614L. At the moment it is running with DD-WRT (eko / svn11100). Is there anyone who got tomato running on that router sucessfully (WLAN + PPPoE)?
January 12, 2010 11:44 PM
I have a WGR614L where I use tomato .... It works fine and supports WLAN too ...
I have not checked for PPPoE (I dnt need it as of now ).... but it z supported in tomato ...
U can download the tomato builds for WGR614L at :
http://www.myopenrouter.com/download/11490/Tomato-1.25-Firmware-Source-Code-f...
http://www.myopenrouter.com/download/10948/Tomato-Firmware-for-NETGEAR-WGR614L/
Let us know if you need any further info ..
January 13, 2010 11:17 AM
Is it possible to use WPA/WPA2 with this release?
How about the stability?
January 18, 2010 11:58 PM
Yep WPA/WPA2 is supported there ...
January 29, 2010 7:46 AM
Have any of you been able to use N speed (150-300mbit) on the WNR3500L wireless using tomato? An earlier comment suggests that even though its not available in the GUI the router defaults to N speed.
I can get connected using N setting om my wireless card but the transfer speed is equal to G (54Mbit). When switching to original Netgear firmware i get proper N speeds.
Maybe possible to telnet/ssh into the router and edit some config file?
Any ETA on WPA support in Tomato?
February 3, 2010 2:28 AM
Hottar said: Have any of you been able to use N speed (150-300mbit) on the WNR3500L wireless using tomato? An earlier comment suggests that even though its not available in the GUI the router defaults to N speed. I can get connected using N setting om my wireless card but the transfer speed is equal to G (54Mbit). When switching to original Netgear firmware i get proper N speeds. Maybe possible to telnet/ssh into the router and edit some config file? Any ETA on WPA support in Tomato?
i've wrote some news here ,
 http://www.myopenrouter.com/forum/thread/16881/How-I-change-from-DD-WRT-on-th...
February 3, 2010 1:41 PM
Whenthelight said:
i've wrote some news here ,  http://www.myopenrouter.com/forum/thread/16881/How-I-change-from-DD-WRT-on-th...
Great news!
Will try it out!
Discussion:    Add a Comment | Back to Top | Comments 1-19 of 19 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
