Learn about scoring Forum's Raw Score: 518693.0
June 9, 2008 04:30 AM
Categories: WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
kaustab
Member
Hi all,
I have downloaded the tomato firmware from this site. WPA-PASK and WPA2-PSK is not working in this firmware. I have downloaded the code also like to debug this problem. Can anybody please inform me where to start with?
Discussion:    Add a Comment | Comments 1-17 of 17 | Latest Comment
June 9, 2008 4:40 AM
The problem lies in the wlconf tool. wlconf can not set the psk to the driver successfully. This ioctl returns -1. The wlconf source is located in the 'src/router/wlconf' directory. check the wlconf routine in wlconf.c.
June 9, 2008 4:47 AM
Thanks for the quick reply. Things are not still very clear to me. Can you please elaborate the mechanism.
June 9, 2008 5:20 AM
when you save any configuration from UI, cgi sets different nvram attributes according to the value you changed and starts the wlconf tool. This tool reads the values from nvram and set those info to the wireless driver.
In our case nvram is getting updated properly but the wlconf fails to set the PSK value to the driver. That's why the AP is behaving as a non secured one.
June 13, 2008 4:26 AM
thanks a ton... I have started to look into the code will update you the proceedings.
November 15, 2008 5:44 AM
Hi all, this seem to be a problem for me too. it's November now, has anyone got a fix for this? Is WPA broken for everyone? is there a workaround?
thanks
View unverified member's comment - posted by Michael
January 20, 2009 1:29 AM
no, i've stopped caring, I am selling my router due to no support available for tomato at all, ie internet does not work, wpa does not work, ssh does not work and no-one on the forum has helped at all to try and get it working. not very happy with the device either, the wireless signal strength is terrible and the fact you have to solder things to get a bricked router (which happens very easily) is not very enticing.
Should have gone with linksys
January 21, 2009 11:28 PM
Are you able to adjust the signal strength effectively? as the signal strength on netgear is PATHETIC! = 5M. Does everything work? Can you create a PPPOE connection from the router and the internet actually works? Can you ssh into the router?
if so then please provide me with step by step instructions on how to get ddwrt on this router, without bricking, currently running netgear firmware and NOTE this is the EU router. So not all firmware applies
January 22, 2009 12:27 AM
Psypher246 said: Are you able to adjust the signal strength effectively? as the signal strength on netgear is PATHETIC! = 5M. Does everything work? Can you create a PPPOE connection from the router and the internet actually works? Can you ssh into the router? if so then please provide me with step by step instructions on how to get ddwrt on this router, without bricking, currently running netgear firmware and NOTE this is the EU router. So not all firmware applies
For downloading the DD-WRT firmware for WGR614L u can follow the following link :
http://www.myopenrouter.com/download/10752/DD-WRT-v11205-Mini-Build-CHK-For-W...
For installing DD-WRT on the router u can go through the following link :
http://www.myopenrouter.com/article/10339/DD-WRT-for-NETGEAR-WGR614L-Installa...
January 22, 2009 1:36 AM
and this will work on the EU routers?
I'm really sceptical. i have a working router right now that I can sell, if i brick this due to incorrect firmware i'm screwed. it's a very expensive router in my country
January 22, 2009 1:48 AM
Psypher246 said: and this will work on the EU routers? I'm really sceptical. i have a working router right now that I can sell, if i brick this due to incorrect firmware i'm screwed. it's a very expensive router in my country
Unfortunately I have NA version ..so can't confirm this..... I  think it should otherwise we would have two builds available here ..one for EU and one for NA version ....
January 22, 2009 1:50 AM
then i'm sorry but i can't flash anything until i have definite answer
January 22, 2009 1:58 AM
Psypher246 said: then i'm sorry but i can't flash anything until i have definite answer
That's understandable ..... BTW u can go through the following link ....
It has been said here that this firmware supports both NA and EU versuions .... so u can try this out ....
http://www.myopenrouter.com/download/10554/DD-WRT-v10509-Std-Small-Test-Build...
January 22, 2009 2:30 AM
to be honest guys, i've actually already been burned and really cannot afford to end up with a bricked router that has no warranty. I appreciate that you guys have been helping today, this is the most, if any, response I have had from many many posts I have made on this forum in 2 months. And it's actually for those reasons I am just going to sell this router as is, with a working netgear firmware.
thanks anyways, good luck
October 14, 2009 4:26 AM
Does anybody know Netgear router with WPA security, which is running under Tomato ?
Thanks in advance
KC LEE
Discussion:    Add a Comment | Back to Top | Comments 1-17 of 17 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
