Learn about scoring Forum's Raw Score: 10609.4
July 12, 2008 04:22 PM
Categories: WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
marcmo
Member
I saw the thread with a similar issue on Tomato but I thought I would start a new one.  I installed the WRT image from this web site, I had to do the reset to login but all in all it went well.  The only thing that look soff to me is the test light (check mark) being lit up with an amber light as well as the wireless light being amber too.  The wireless works I just don't recall the light being amber.
I'm pretty sure this wasn't the case with the default firmware, is this safe to ignore ...
Marc Mondragon
Discussion:    Add a Comment | Comments 1-2 of 2 | Latest Comment
July 16, 2008 8:33 AM
yes, I guess you can safely ignore it..
August 9, 2008 10:48 PM
Hey.
I have the same problem. Everything works well when I finished uploading DD-WRT firmware to my netgear router, but the check amber light is always on, and the wireless signal is amber too. What do they mean?
Has anybody done a "hard" reset for this problem?
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
