OUR NETWORK:TouchSmart Community TiVo Community TechLore Sling Community My DigitalEntertainer See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 106894.0
August 24, 2008 08:27 PM
Categories: WGR614L Open Source Router
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
TheGuru
Member
Is it possible to use a standard RS232 serial cable with the console connection instead of the USB cable? I had a DB9 serial header which I soldered to the board with the appropriate TX/RX/GND config from the article that explains the USB cable.
At one point it was working and I could see the board going through the boot process, and the firmware I had uploaded was having an error, which causes the router to reboot.
However, CTRL+C would never drop me down to the CFE bootloader to start up TFTPD. So I tinkered with it some more, thinking maybe I had a bad solder or something keeping me from getting input sent properly, but no dice.
Now when it goes though boot I basically get garbage on the screen equivalent to where it used to give me legible data. It also used to say "Loading" then print periods to the screen to indicate progress. Instead of periods, I now get "4"'s.
By using a straight serial cable did I fry something?  Is this possible?
Discussion:    Add a Comment | Comments 1-5 of 5 | Latest Comment
August 25, 2008 8:01 AM
Standard RS232 operates at -5 - +12 volts but this board is supposed to work at 3.3 v. So it is not possible to connect throufg RS232.
August 25, 2008 11:00 AM
So by doing so would I have caused unrepairable damage? Do you know of a place to get the right cable. The link to Moser has it as "Discontinued".
August 26, 2008 12:27 AM
order for 895-TTL-232R-3V3 at http://www.mouser.com Looks like the link had changed.
September 8, 2008 9:14 PM
Got the cable and everything is working now, didn't fry the router with the normal serial cable.
September 8, 2008 11:01 PM
Congrats....
Discussion:    Add a Comment | Back to Top | Comments 1-5 of 5 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
