Learn about scoring Forum's Raw Score: 304004.0
August 27, 2008 12:44 AM
Categories: WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
wasabioss
Member
So, I have bricked my router with the newest DD-WRT firmware posted on this site. Maybe I was in bad luck (because I flashed it successfully with tomato and MRO several times before.) The POWER LED of the router does not blink at all so I don't think that I can debrick it with TFTP. The router has solid POWER and CHECK lights solid and whichever port I connect my LAN cable to solid.
I wonder if I could use my serial port on my laptop which is a Dell D610 to connect the JTAG or the USB to serial 3.3Volts cable is strictly needed, because I will have to order it and wait for weeks to begin using my router which is a little bit silly.
Discussion:    Add a Comment | Comments 1-3 of 3 | Latest Comment
August 27, 2008 7:59 PM
So, I went ahead and tried to connect the JTAG pins with my laptop. Something was going on but they were all garbages (not readable characters) on my terminal. I tried with several different computers. So is that a sign to indicate my voltage rating is not correct?
August 28, 2008 4:19 AM
You need to have the serial to USB cable operating at 3.3 volt. Please do not try any other cable except the one specified in http://www.myopenrouter.com/article/10341/Recover-Your-WGR614L-Using-a-Serial... - this may brick your router..
August 28, 2008 1:13 PM
SouvikGhosh said: You need to have the serial to USB cable operating at 3.3 volt. Please do not try any other cable except the one specified in http://www.myopenrouter.com/article/10341/Recover-Your-WGR614L-Using-a-Serial... - this may brick your router..
 That's not exactly true - you can use a serial level shifter too based on MAX3221.
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
