OUR NETWORK:TouchSmart Community TiVo Community TechLore Sling Community My DigitalEntertainer See all... About UsAdvertiseContact Us
Learn about scoring Forum's Raw Score: 199492.0
August 30, 2008 11:20 PM
Categories: Setup / Configuration
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
bfritton
  Member
Hey all,
Does anyone know of any problems coupling a Linksys WRT54GL with the WGR614L?
I turned off DHCP on the Netgear router (running latest DD-WRT) and set my gateway to the parenting Linksys. I also set the DNS correctly. The DHCP is enabled on the Linksys to that it can hand out IPs.
Sometimes I am unable to see network shares on computers hooked up to the Netgear from a computer hooked up to the Linksys even though they should be on the same subnet now.
 Perhaps just a sporatic problem or me not waiting long enough for discovery?
Discussion:    Add a Comment | Comments 1-3 of 3 | Latest Comment
September 4, 2008 11:22 PM
I am trying to do almost the exact same thing and am having the same problem. Any ideas?
September 5, 2008 4:50 PM
You should have the two devices connected via the station port to station port, and have nothing connected to the uplink/internet port of the second device. If you do want to daisy chain the second device using it's uplink port, then you will need to make sure they are on *different* subnets, otherwise expect NAT to the confused... Put one on 10, and one on 192.168 for exacmple.
September 15, 2008 7:02 PM
Thanks for the info John,
I actually did all that with all the correct settings. After messing around a bit I found out that I must have just been too impatient with the router starting up and restarting. Once I left the router alone for a little while and made the changes after a restart then waited more than one minute then the configuration changes worked perfectly.
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
