Learn about scoring Forum's Raw Score: 779348.0
December 19, 2008 05:33 AM
Categories: DD-WRT
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
achilles
Member
Hi all ,
I want to compile DD-WRT v24-sp1 but I am not able to do this and I am getting following error message while trying to
do so .....
 /DD-WRT/toolchains/3.4.6-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/3.4.6/../../../../mipsel-linux-uclibc/bin/ld: iptables: hidden symbol `__udivdi3' in /DD-WRT/toolchains/3.4.6-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/3.4.6/libgcc.a(_udivdi3.oS) is referenced by DSO
/DD-WRT/toolchains/3.4.6-uclibc-0.9.28/bin/../lib/gcc/mipsel-linux-uclibc/3.4.6/../../../../mipsel-linux-uclibc/bin/ld: final link failed: Nonrepresentable section on output
Could any one plz tell me what can be the reason behind this and how to overcome it ????
thanks in advance ,
Discussion:    Add a Comment | Comments 1-15 of 15 | Latest Comment
December 22, 2008 12:14 AM
It is most probably toolchain issue. Somewhere your cross compiler may be corrupter or you might be using wrong cross compiler. Can you please download the fresh toolchain and try it again ?
January 1, 2009 3:34 AM updated: February 9, 2009 12:16 AM
Tathagata Das said: It is most probably toolchain issue. Somewhere your cross compiler may be corrupter or you might be using wrong cross compiler. Can you please download the fresh toolchain and try it again ?
thnx for the suggestion ... now I am able to compile it though with a different tool chain ... previously I was using 3.4.6-uclibc-0.9.28 but now I am using 4.1.0-uclibc-0.9.28 and compilation is through ... :)
February 8, 2009 12:24 PM
I am trying to compile all from source, and having a similar issue. You mention you were using:
3.4.6-uclibc-0.9.28 and now using:
3.4.6-uclibc-0.9.28
I am not sure I understand the difference.
It does appear to want a different (or at least different location) for the tool chain.
I followed the direction at (and brought in the full 20gb kernel source for all versions): http://www.dd-wrt.com/wiki/index.php/Development
February 9, 2009 12:15 AM
John Lauro said: I am trying to compile all from source, and having a similar issue. You mention you were using: 3.4.6-uclibc-0.9.28 and now using: 3.4.6-uclibc-0.9.28 I am not sure I understand the difference. It does appear to want a different (or at least different location) for the tool chain. I followed the direction at (and brought in the full 20gb kernel source for all versions): http://www.dd-wrt.com/wiki/index.php/Development
Sorry john, In my last post I mentioned the same tool chain twice by mistake .... actually the tool chain version that you need to get compilation through is :
4.1.0-uclibc-0.9.28
Use this and u will be able to compile the DD-WRT distribution .....
February 11, 2009 9:17 PM updated: February 11, 2009 9:38 PM
Sorry john, In my last post I mentioned the same tool chain twice by mistake .... actually the tool chain version that you need to get compilation through is : 4.1.0-uclibc-0.9.28 Use this and u will be able to compile the DD-WRT distribution .....
Ok, that makes sense when I get to that point.  Right now I am having problems just running the prep scripts.  I started fixing some non portable code in jsformat and build for squashfs, but decided I rather work on the main router code instead of the build environment, or I may run into problems later on that I don't notice as it appears to be tied to specific distro...  I tried both 64-bit and 32-bit Centos 5, but it appears that Debian is what I should have used, as apparently Debian has some gcc patches that makes it behave differently.  Should I use the 32-bit distro or a 64-bit AMD distro, or better yet, what ISO should I reinstall from that will give me the least issues building?
February 11, 2009 11:53 PM
Yep , there are some problems in running prep scripts due to 32-bit and 64-bit environment issues .... I would suggest u to use the 32-bit distro ...
BTW I have prepared few scripts to automate download and build of DD-WRT for WGR614L ... I have tested them on FC6 and will post them very soon ...
you can use those scripts or at least take some clue from there...
Also I would sugeest u to go through the following link at least once :
http://www.dd-wrt.com/phpBB2/viewtopic.php?p=165514&sid=41cf23dbcd2ffadb2fa42...
It has mention and solution of several common DD-WRT compilation issues ...
February 12, 2009 7:12 AM
32-bit FC6? Kind of old (10 is current), but found an archive that has it. Downloading as I type this... so I will be ready for when you post the build scripts. :) Thank you.
February 12, 2009 7:24 AM
John Lauro said: 32-bit FC6? Kind of old (10 is current), but found an archive that has it. Downloading as I type this... so I will be ready for when you post the build scripts. :) Thank you.
ya it z old but I did not feel the need of changing it for the time being ..... BTW i have posted my scripts but currently it z in the review queue ....
BTW if u r done with the download I can suggest u the steps that need to proceed ....
Just copy the following stuff in a shell script in xxxx/yyyy/DD-WRT/opt and run it ....
cd ../src/router
make clean
make
make install
cd -
./sstrip/sstrip ../src/router/mipsel-uclibc/target/bin/*
./sstrip/sstrip ../src/router/mipsel-uclibc/target/sbin/rc
./sstrip/sstrip ../src/router/mipsel-uclibc/target/usr/sbin/*
cp ./bin/ipkg ../src/router/mipsel-uclibc/target/bin
cp ./libgcc/* ../src/router/mipsel-uclibc/target/lib
cd ../src/router/mipsel-uclibc/target/lib
ln -s libgcc_s.so.1 libgcc_s.so
cd -
cp ./etc/preinit ../src/router/mipsel-uclibc/target/etc
cp ./etc/postinit ../src/router/mipsel-uclibc/target/etc
cp ./etc/ipkg.conf ../src/router/mipsel-uclibc/target/etc
cp ./etc/config/* ../src/router/mipsel-uclibc/target/etc/config
cp ./usr/lib/smb.conf ../src/router/mipsel-uclibc/target/usr/lib
cd ../src/router/mipsel-uclibc/target/www
ln -s ../tmp/smbshare smb
cd -
../src/linux/brcm/linux.v24_2/scripts/squashfs/mksquashfs-lzma ../src/router/mipsel-uclibc/target target.squashfs -noappend -root-owned -le
echo "<------- Creating TRX image -------->"
./tools/trx_wgr614 -o linux.trx ./loader-0.02/loader+400.lzma ../src/router/mipsel-uclibc/vmlinuz -a 1024 target.squashfs
echo "<-------- Creating CHK image ---------->"
touch emptyfile
echo U12H072T00_NETGEAR >> compatible.txt
./tools/packet -k linux.trx -f emptyfile -b compatible.txt -ok kernel_image -oall dd-wrt -or rootfs_image -i emptyfile
rm -f emptyfile compatible.txt kernel_image.chk rootfs_image.chk
I hope this will help u out .......
February 13, 2009 4:16 AM
@achilles
I have also gone through the hardship that is required to compile the DD-WRT distribution .... though I am able to get it compiled but I am looking forward to get your scripts from this site and test them for my build ....
When will your scripts be available .... Will it be a beta release ?... Will there be any instructions to use them and have you tested them on anything other that FC6 ....
thnx
February 13, 2009 5:22 AM
imran said: @achilles I have also gone through the hardship that is required to compile the DD-WRT distribution .... though I am able to get it compiled but I am looking forward to get your scripts from this site and test them for my build .... When will your scripts be available .... Will it be a beta release ?... Will there be any instructions to use them and have you tested them on anything other that FC6 .... thnx
It will be available very soon and it will be a beta release ..... All suggestions/feedback for improvement of these scripts are welcome .... There will instructions to utilize these scripts ..... Besides FC6 I have tested it on FC9 ....
February 13, 2009 12:49 PM
It took a long time to get FC6 downloaded and installed... download rate was about 1/10th of what I was used to.
The good news, switching to FC6 helped in that I was able to get further without having to modify the C code or makefiles. However, still running into some problems well before it compiles everything.
It does go further, but unfortunately, I have not been able to compile it all. Should I run the script you run prior to, after, or instead of the scripts mention on dd-wrt ( 0. Run ready_ddwrt.sh and ready_ddwrt_root.sh, and in DD-WRT/opt run ./install.sh. Running ./install_* to build a particular variant requires you rebuild shared code first.)? The make command did prompt for several configuration options.
The error I am receiving:
In file included from /home/ddwrt/DD-WRT/src/router/shared/wlutils.h:19,
from utils.c:25:
/home/ddwrt/DD-WRT/src/include.v23/wlioctl.h:24:28: error: proto/bcmevent.h: No such file or directory
That file is in include.v24, but not include.v23. I am tempted to just copy it and see.
February 13, 2009 5:45 PM updated: February 15, 2009 4:32 PM
I see your scripts were posted, and after some reworking of the tool chains I was able to get them to work, but have not tried to upload it to a router yet...
A pointer as to which version(s) of the toolchains you have installed and thus are known to work would be a helpful addition to your documentation or scripts.
I do have cables on order and want to put that mod in place first in case I brick it...
February 15, 2009 11:09 PM
John Lauro said: I see your scripts were posted, and after some reworking of the tool chains I was able to get them to work, but have not tried to upload it to a router yet... A pointer as to which version(s) of the toolchains you have installed and thus are known to work would be a helpful addition to your documentation or scripts. I do have cables on order and want to put that mod in place first in case I brick it...
The toolchain version that I am using in my builds is :
4.1.0-uclibc-0.9.28
Keep us posted about your findings once you flash your router with this image ...
April 9, 2009 9:09 PM
The toolchain version that I am using in my builds is : 4.1.0-uclibc-0.9.28  Keep us posted about your findings once you flash your router with this image ...
Sorry for the delay in getting back on this...  It flashed just fine and is working!  Made some minor mods (just to verify I can reproduce), and reflashed and all is well.  (Actually had trouble the second time getting it to twork with a .trx file and messed it up, but was able to push a .chk via tftp).  Would be nice if dd-wrt support .chk files directly, or if the build process also made a .bin that could be used once it's in dd-wrt mode.
April 9, 2009 11:05 PM
Hi John,
Thanx for update from ur side ... I will definitely look into your suggestion and try to write some scripts that will create a bin image which can be flashed into WGR614L ....
Discussion:    Add a Comment | Back to Top | Comments 1-15 of 15 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
