Learn about scoring Forum's Raw Score: 89057.1
December 25, 2008 02:29 PM
Categories: WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
teamworker
Member
I use dd-wrt 11218 miniBuild (2,8MB) on my 614Lv8 WW Model.
This build has no openvpn Services integrated.
Only the unsecure PPTP
Q1:
I have read, 614Lv8 WW not the NA Model  can't install *.bin files with the GUI from dd-wrt.
WW 614Lv8 Model can only use *.chk files, per tftp to upgrade
Is that right?
There is no Std/smal 11218.chk in Elko's new builds, only Std/Smal *.bin for 614Lv8 .
Q2:
rename Std/smal *.bin in *.chk is that a way?
thnx for Anwers.
Greetings Teamworker
Discussion:    Add a Comment | Comments 1-5 of 5 | Latest Comment
December 29, 2008 12:17 AM
Yes, only *.chk files are upgraded into the board through GUI or tftp.
If you have one bin file then you have to convert it to chk file. Only renaming the extension will not solve this problem. You can try this tool to convert it to chk image. http://www.myopenrouter.com/download/10611/mkchkimg/
December 29, 2008 3:01 PM
Big thx to Tathagata Das
Please read my BIG Problem under:
http://www.myopenrouter.com/forum/thread/10766/vmlinuz-Problem/
December 29, 2008 8:58 PM
tryin to use my netgear router but lost my netgear cd
December 30, 2008 4:11 AM
billy said: tryin to use my netgear router but lost my netgear cd
It is not clear from your post why do you need the CD .... the reset button on the board can be used to get back factory defaults .
Then you can access board's GUI at 192.168.1.1 and configure the board as per your need
December 30, 2008 5:31 AM
What do you want to do with Netgear router ? It is not clear to me why you need CD to access the router.
Discussion:    Add a Comment | Back to Top | Comments 1-5 of 5 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
