Please look into the thread :
http://www.myopenrouter.com/forum/thread/10570/WGR614-chksum-problem/
It is an alignment issue ... hope u will get ur prblm solved using the solution given here ...
Hi all,
I have build a DD-WRT firmware and flashed my WGR614L with it . With this f/w the board boots OK .... the problem is that with this f/w factory hard reset does no work properly and whenever I do a factory hard reset the boot fails with the following error message :
CFE for WGR614v8 version: 1.3
Build Date: Fri Apr 20 14:04:44 CST 2007
Committing NVRAM...done
Device eth0: hwaddr 00-1E-2A-07-AC-8A, ipaddr 192.168.1.1, mask 255.255.255.0
Loading .................................
Image chksum: 0x0DE968E6
Calc chksum: 0x8F3666A7
Loading: . 0 bytes read
Failed.
Could not load flash0.os:: Error
CFE>
Now subsequently if I again flash the router with my DD-WRT f/w using tftpd ... the boot happens properly and all things become OK ....
Problem arises whenever I try to do a reset .... It seems there is some mistake .....
Could anyone plz provide me with some ideas in this regard ....
thnx in advnc ....
thanks achilles ,
Now hard reset is working with the image built by me ... thanks again
RSS
