February 15, 2009 11:31 PM
What is the format of image which is causing pblm and what is the format of correct image ... Have u checked this ...
It seems that ur image is not in correct format odrwise at least f/w upgrade would
have happened ..
For .config file u can use the same .config avlbl in the downloaded src code ..
But I dnt think ur pblm has got anything to do with .config ..
