Learn about scoring Forum's Raw Score: 325004.0
April 3, 2009 07:58 PM
Categories: WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
rtg20
Member
Hi, I've spent a really really really long time on this...
I own a vet clinic and we have a network, mostly wired but also a WPA wireless network.
We recently bought an ultrasound machine. It only supports WEP!
So I want to use a WGR614L to make a WEP network and connect it (using the 'Internet' port on the back of the WGR614L) to rest of the network. I need the ultrasound software running on the server to be able to 'see' the ultrasound unit.
Here's the setup:
192.168.0.1 - main router (connects to our DSL service) - it's a Netgear DGN2000
192.168.0.2 - server with the ultrasound software
192.168.0.52 - 'Internet' interface of WGR614L. connects to our main router 192.168.0.1.
192.168.1.3 - Ultrasound machine, connected by WEP to the WGR614L
I thought by telling the ultrasound software on the server to look for the ultrasound machine at 192.168.0.52 it would work, providing the port-forwarding was set up. But it doesn't. I even tried making 192.168.1.3 a DMZ! But it still doesn't work.
I've spent several hours on this, without success. The ultrasound unit itself is fine, because if I make my laptop part of the WEP network and install the software on it then it sees the ultrasound unit.
The idea is that the ultrasound user can save ultrasound images to our main server 192.168.0.2, and since no one else will be using the WEP, i can lock it down.
I'd really appreciate some help!
thanks,
Discussion:    Add a Comment | Comments 1-3 of 3 | Latest Comment
April 6, 2009 12:37 AM
First of all I must tell you that this an almost detail description of your problem. Thank you for providing that.
Are you able to connect your ultrasound m/c to WGR614L ? How do you check that ?
Please do following test to check whether WGR614L is okay or not.
1. Connect your laptop to your WGR614L using wireless and WEP enabled.
2. You should be able to associate. Then do a ping from your laptop (it should have one ip like 192.168.1.x) to WGR614L (Hope it is 192.168.1.1)
3. Do a ping to 192.168.0.52 from your laptop.
4. Do a ping to 192.168.0.1 as well.
5. Do a ping to 192.168.0.2.
Please let me know the test results of those above tests.
April 8, 2009 4:49 PM
This post was a few days ago. Still working on it?
When you make your laptop part of the WEP network do you give it a static IP or does it negotiate its own IP.
Either way look and see what IP address it uses when connects and post it back here.
http://placeshiftingenthusiasts.com/
April 11, 2009 11:02 AM
BrandonC said: This post was a few days ago. Still working on it? When you make your laptop part of the WEP network do you give it a static IP or does it negotiate its own IP. Either way look and see what IP address it uses when connects and post it back here.
thanks for the replies. in the end I decided to use the second router as another AP.
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
