Learn about scoring Forum's Raw Score: 142091.0
December 17, 2009 03:39 AM
Categories: Setup / Configuration
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
e93jl
Member
I ordered my router a while back but it's still out of stock. This might be something easy to find out once I get it...
Is it possible to assign different private lans to different ethernet ports on the router?
I would like to have one lan as trusted and one as untrusted. I still have some devices that are WEP only and want to connect a separate wireless router to one port and give it a specific ip adress pool.
Splitting the wireless network directly in the WNR3500L would be nicer, but I guess that's to much to ask for.
Discussion:    Add a Comment | Comments 1-10 of 10 | Latest Comment
December 21, 2009 5:23 AM
You can split the wireless network if your f/w supports virtual APs ... I dnt know abt others but DD-WRT supports virtual APs ... so you can use it for ur purpose ....
December 22, 2009 12:09 AM
You can assign different private LAN on to different Ethernet ports and to do that you need to configure vlan properly. Also there are some nvram parameters which need to be changed accordingly.
Moreover, change in configuration varies from firmware to firmware. Like configuration mechanism in Tomato, OpenWRT and DD-WRT are different. So you need to use different techniques.
December 28, 2009 3:43 AM
Great stuff, thanks guys.
December 28, 2009 11:52 PM
That's nice ... have u configured it ... If u could share ur experience that would be helpful for other ppl here ..
December 29, 2009 2:27 AM
My router is in the mail, so I'll get back to you in a week or two.
December 29, 2009 3:52 AM
that's fine .... no probs ... all d best .. :)
January 8, 2010 3:12 PM updated: January 8, 2010 3:33 PM
I got the router and started flashing DD-WRT, no problem.
Found a guide on the topic at hand: http://www.dd-wrt.com/wiki/index.php/VLAN_Detached_Networks_%28Separate_Netwo...
January 9, 2010 6:18 AM
Still contact between the two LANs after performing all steps.
I can see, after telnetting to the router, that the setting in step 1 isn't implemented. No vlan3 and port 2 is still part of vlan2 (for some odd reason vlan2 == WLAN as default in my firmware)
Tried disabling port 2 using the settings under VLAN without success. Something isn't right.
October 5, 2010 2:44 PM
I have the same problem, either the GUI or Telnet config works...
October 5, 2010 2:45 PM
I have the same problem, anyone got it working?
Discussion:    Add a Comment | Back to Top | Comments 1-10 of 10 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
