Hi Nox997 !
Yes, this firmware is fully compatible.
I use it since a couple of weeks.
I think there is an issue with the MAC addresses (not the correct ones).
I also use Optware which is amazing !
You can fully trust eko and his firmwares.
Hi!
As I don't want to brick my new WNR3500L, I'd like to know whether "dd-wrt.v24-13575_NEWD-2_K2.6_big.bin" on this site (http://www.dd-wrt.com/site/support/other-downloads?path=others%2Feko%2FV24-K2... is compatible with my router?
By the way how can I generally tell whether it could be possible that a certain firmware is compatible or not?
Thanks in advance for answers!
There is a new build here:
http://www.dd-wrt.com/site/support/other-downloads?path=others%2Feko%2FBrainS...
Great reading before you upgrade: http://www.dd-wrt.com/phpBB2/viewtopic.php?t=51486 Netgear 3500L Tomato beta 22 and 3x Fonera 2100 Gargoyle 1.3.5
RSS
