hey i have same problem and question please inform me if u have find solution!
Hello.
i have flashed my WNR3500L with the DD-WRT Firmware. But now i want to restore the original netgear Firmware.
When i slect it in the WebGui it says wrong file. I also changed the ending from chk to bin and tried. but upgrade fail again.
Is there a solution for it ?
Best regards
dodo
Same problem here too. I don't know how to do this. For the WRT54G there is a VxWorks firmware which could do this. I have no idea if the 3500L supports this.
Look at this thread. It helped me when I reverted back to the stock firmware.
http://www.myopenrouter.com/forum/thread/16084/Back-to-stock-firmware/
See this article.
How To Reflash Factory Firmware on the NETGEAR WRN3500L Without A Serial Cable
http://www.myopenrouter.com/article/16099/How-To-Reflash-Factory-Firmware-on-...
That's the best single article on this site. Saved me a few times with bad dd-wrt.
Thnx, it worked. It was quite simple. I used the post of pen:
- '/sbin/mtd erase linux' in a telnet session (It's part of dd-wrt)
- Reboot the router
- 'tftp -i 192.168.1.1 PUT code.chk' from windows
- Reboot the router
- Factory reset by pressing button on back of router to get default user/password
worked like a charm. I still think the router sucks.. too bad.
Kevin said: That's the best single article on this site. Saved me a few times with bad dd-wrt.
Kevin, Glad it helped. But with the new Tomato beta that is out there I am loving the easy way it lets you share files via the USB drive. I have switched to it just because of it. Article to come soon.
I have to revise my opinion on the router. I've succesfully installed tomato 1.27 beta03, which works great!
The download contains a trx file, which can be installed from the dd-wrt initial flash firmware. Therefore you have to rename the .trx file to .bin. After that, everything works fine :D. I simply love tomato!
RSS
