You'll probably want a newer or older version of DD-WRT - that one is known to have issues (search both this and the DD-WRT forum).
It could also be a corrupt download, but as you don't say what the problem is it's hard to suggest what the cause could be.
I have downloaded dd-wrt.v24-14311_NEWD-2_K2.6_big.bin. But I can not load it in my board. I have upgraded my board many times with different firmware in chk format. I do not know whether it the problem of bin format or not. Is there any way to change from bin to chk format.
June 9, 2010 12:37 PM
June 12, 2010 5:50 AM
Trailed builds (builds with router name in it, for netgear its always the .chk files) are for the initial flash only, they have a special header in it for the router default firmware to accept the image, after that, you simply use the .bin files because dd-wrt doesn't care about the header info anymore.
RSS
Hi All,
DD-WRT supports to upload bin file format. Upload older version of ddwrt in chk file format using tftp. then upgrade it through web.
