Learn about scoring Forum's Raw Score: 158716.0
July 31, 2010 06:57 AM
Categories: Troubleshooting
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
shinoda
Member
Hi there !
Yesterday, I tried to install a dd-wrt firmware but after the update, my router didnt start as usual, the power led stays amber/orange (not blinking). I tried to telnet the router but i couldnt (host connection impossible, that sort of thing). A reset and even a 30:30:30 reset does nothing (led isnt changing at all, it stays amber).
So I started using a Linux live cd to tftp the stock firmware just at the boot with this guide (http://www.myopenrouter.com/article/13702/Recover-Your-Bricked-NETGEAR-WGR614... but it always says "transfer timed out" (my router could be pinged anyway). I don't know if I'm in a pretty bad situation or not but I'm starting to worry. Is the serial cable debrick way the only one effective ?
Thanks !
Discussion:    Add a Comment | Comments 1-6 of 6 | Latest Comment
July 31, 2010 8:23 AM
Did you set a static IP on the PC? Try 192.168.1.9, gateway 192.168.1.1
Netgear WNDR3700V1
July 31, 2010 9:29 AM
Yes, I was on a static ip with the right gateway.
July 31, 2010 9:53 AM updated: July 31, 2010 9:53 AM
It's strange that you can ping it but not tftp due to timeout error. Can you ping it continuously or is it only for a short time? If the latter, maybe correct timing of the tftp command is crucial.
Netgear WNDR3700V1
July 31, 2010 9:56 AM
I can see two ping commands before the router is not responding. I tried several times, flooding the tftp cmd even before the pings appear, to be sure :/
I'll give another try later...
July 31, 2010 1:39 PM
If you see only two pings, then tftpd has not been started, there are two ways to fix it short pin method or serial connection:
Press Reset Button, Power on. Wait about 30s, release Reset Button, once you receive the first ping short pins, now ping should continue.
http://www.myopenrouter.com/article/20501/Reset-Debrick-NETGEAR-WNR3500L-Pin-...
http://www.myopenrouter.com/article/13859/How-To-Debrick-Your-NETGEAR-WNR3500...
August 11, 2010 10:09 AM
Ok guys, so I bought a serial cable before noticing that my router does not have a serial port. So what can I do ? :/
Discussion:    Add a Comment | Back to Top | Comments 1-6 of 6 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
