Learn about scoring Forum's Raw Score: 577673.0
August 26, 2010 12:35 AM
Categories: Setup / Configuration
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Slick
Member
Dear all,
This might be a pretty dumb question. I recently got a WNR3500L running the latest stock firmware as I've yet to try out DD-WRT or Tomato. Anyway, according to the official Netgear website, they said this model feature a Wireless On/Off switch but I don't see one at the back of my 3500L. I also don't find any topic on the manual mentioning this feature. Do you need to turn that off by logging into the network? To make it simple, what's the proper way to turn on/off the wireless signal on this router.
Lastly, I'm just curious does turning off the router when not in use really save up to 30% of energy? I mean are there any tests out there that measures if the result is consistent with netgear's claim? What about if I flash it to Tomato/Open WRT or whatever. Do I still get this feature of turning off the wireless signal? Thanks and sorry if I sounded like a noob.
Discussion:    Add a Comment | Comments 1-13 of 13 | Latest Comment
August 26, 2010 8:33 AM
There is a power on/off switch on the back, but i have not seen a wireless on/off button.
I think you can go into the GUI and disable wireless under wireless settings. I don't know whether you would save 30% but surely there would be some energy savings if the radio is not transmitting/receiving for the night.
Netgear WNDR3700V1
August 27, 2010 10:50 AM
@taekwon3dan
I don't think there's such feature on the 3500L stock firmware. Oh well, it's not really that of a big deal, I guess turning off at night seems to be the only option as I'm on a habit of going green. Thanks anyway!
August 28, 2010 12:54 AM
Hi Slick,
dd-wrt and tomato feature radio time restrictions. You can specifiy a time period for wireless operation for example radio off from 0:00 - 8:00 am if you suddenly need wireless within that time range you can use the front button on the wnr3500l to activate wireless.
August 28, 2010 3:01 AM
@Kong
Oh really? Great man, Netgear should feel so ashamed of their feature-less firmware. It's even more ironic that they post that feature on their product info. Anyway, Kong, I'm still on the verge of choosing between DD-WRT and Tomato (as like many other guys are the same). I heard that DD-WRT degraded over the years and that Tomato had better performance and more user friendly, was that really the case? If so, I'll probably go with Tomato since I'm really on an amateur level. Thanks for you help and suggestion!!
August 28, 2010 5:18 AM
Before my dd-wrt mod this was true. My version contains various fixes + optimizations that make it even faster than tomato. Some things are done differently with tomato, maybe some features are easier to setup, but that usually depends on the user.
DD-WRT has a few more features, but regular users usually don't need these advanced features.
Therefore, both are good choices. In rare cases some feature may work on dd-wrt but not on tomato and the other way around.
P.S. Before I bought the wnr3500l I checked lots of router manuals, original firmwares usually don't have the radio schedule feature. Linksys Netgear... don't have it only one I knows that has it included in vendor firmware is AVM.
So i picked the wnr3500l because I knew I could put a firmware on it that allows to automatically turn of radio at night. Besides that you can do a lot more cool things with it.
October 5, 2010 9:41 AM updated: October 5, 2010 9:42 AM
Long time Tomato user here. I've tried DD-WRT and OpenWRT before. The QoS in DD-WRT doesn't really work. I mean I give my online game highest priority and it still lags while my roommate is doing something. Tomato QoS on the other hand works best of all I've tried. I can game/skype/surf whatever even if other ppl are downloading/youtubing/etc on the same line.
And another thing. I tried DD-WRT and changed some settings. Clicked Save. ROUTER RESTARTS AFTER EVERY CHANGE YOU MAKE. Like WTF is that. Clunky interface too. Tomato uses AJAX and when you save a setting it changes it in the background. You can still use your router, nothing goes away.
Just my 2c.
P.S. before I forget. You can turn off Wireless with 1 click in Tomato's 192.168.1.1 menu. I'm pretty sure you can even program the button on the router to do that.
October 5, 2010 12:33 PM
DD-WRT's interface has been using ajax techniques for some time now.
When was the last time you tried dd-wrt, 1y or 2y:-)
DD-WRT now features both HTB/HFSC shedulers.
P.S.: In Tomato and dd-wrt you can set a time shedule when wireless should be turned off. Seems like you're not up to date with latest development.
August 31, 2011 5:14 PM
I've just upgraded tomato to the latest version 1.28 on my Linksys WRT54GL, and I can't find any part of the GUI that allows me to set a time schedule when wireless radio should be turned off (and on again).
Can anyone give a hint where to look in the GUI? Thanks in advance!
September 4, 2011 3:44 PM
Access Restriction
September 4, 2011 4:36 PM
dafek said: Access Restriction
Well, but isn't that just for what it says? I believe I could configure the router so it doesn't allow access during night. But I want the router to stop sending a signal at all, to turn off the WLAN radio completely during night.
(I have no tools to measure the radiation emitted by the router, so forgive me that I write a reply before simply "trying it out" beforehand.)
September 4, 2011 4:44 PM
i don't have tools either so we both have to believe that when it is set to off then it is off :) at least the blue light in my 3500l went off.
and you can always decrease the signal strength, if you dont need it at full power. this will save you some energy at day also i think.
September 4, 2011 5:10 PM
Thanks, you're right. Also the light for "WLAN" on my Linksys WRT54GL goes off. And after all the "type" option for a new Access Restriction rule says "Normal Access Restriction" vs. "Disable Wireless"
Maybe "Access Restriction" is a little bit misleading as a name. Some people (like me) don't use this for security purposes but for health reasons: reducing radiation while sleeping. Just my two cents...
THANKS AGAIN for your help!
April 6, 2012 4:41 PM updated: April 6, 2012 4:43 PM
I just recently switched to dd-wrt so I don't have the stock firmware anymore, but I distinctly remember seeing a option to turn wireless radio on/off based on time in the web ui. I set mine to turn off at 12am and turn back on at 6am, for the same reason you have stated. It works well.
I recall seeing this option after I upgraded the stock firmware to the latest one, v1.2.2.44:
http://support.netgear.com/app/answers/detail/a_id/18853
New Features:
Scheduled Wi-Fi on/off.
Discussion:    Add a Comment | Back to Top | Comments 1-13 of 13 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
