http://www.myopenrouter.com/article/13378/Features-and-Specifications-NETGEAR...
"Five 10/100/1000 (1 WAN and 4 LAN) Ethernet ports with auto-sensing technology"
So that must be a yes
Hello guys,
My ISP asked me to upgrade the service to 1Gb connection (I live in Hong Kong).
Does the WAN port of WNR3500L support gigabit connection? This is not clearly mentioned on the offical website.
Thank you very much.
WAN to LAN Throughput:
http://www.smallnetbuilder.com/index.php?option=com_chart&Itemid=189
Fastest router tested (SmallNetBuilder) - WAN to LAN Throughput:
D-Link Xtreme N Storage Router (DIR-685): 659 Mbps
Manufacturer's Description:
Netgear WNR3500L Rangmax Wireless-N Gigabit Router With USB. 802.11n certified technology with Gigabit Ports for faster wired and wireless performance.
* Connectivity: Wireless
* WLAN Standards: IEEE 802.11b IEEE 802.11n IEEE 802.11g
@matrix
But when you look at the review of the DIR-685 it doesn't score that well. I wonder if the results would be different for the WNR3500L with some of the OS firmwares...
@Peter B
Have a look at this topic:
ttp://www.myopenrouter.com/forum/thread/21393/WNR3500L-WAN-to-LAN-throughput-using-different-firmwares/?page=2
Currently I'm using the stock firmware.
Planning to experiment with the Tomato firmware (Teddy Bear mod) and DD-WRT (Kong mod) this month....
I must admit I didn't even try the stock firmware - as soon as I had the WNR3500L connected I flashed to DD-WRT as I had some issues with wifi and IOS devices I tried the Tomato firmware (it worked better than dd-wrt but still not as stable as my Airport Extreme).
Anyways I think it'll be a while before I hit the roof as my bandwidth is "only" 60/60 Mbit/s
Based on the following statistics you're probably hitting the roof in Latvia / South Korea:
http://www.techpinas.com/2010/08/countries-with-fastest-internet.html
RSS
