Learn about scoring Forum's Raw Score: 239462.0
January 16, 2011 07:43 PM
Categories: DD-WRT
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
rbscairns
Member
I have DD-WRT v24-sp2 vpnkong - build 15758M installed on my WNR3500L and decided to try and connect my NTFS formatted WD320GB external USB HDD to the router.
Before connecting the USB HDD, in the GUI I went to Services>USB and set:
  • Core USB = enable
  • USB 1.1 Support (UHCI) = enable
  • USB 1.1 Support (OHCI) = enable
  • USB 2.0 Support = enable
  • USB Printer Support = disable
  • USB Storage Support = enable
  • Automatic Drive Mount = enabled
I then rebooted the router. After reboot, I connected my NTFS formatted USB HDD to the WNR3500L USB port but no light came on on the HDD.
With the HDD still connected, I logged on to the GUI. Going again to Services>USB I find that the USB HDD is not mounted-
[See image galary for screen shot]
I thought maybe NTFS format is not liked, so I disconnected the HDD and reformatted the USB HDD to ext3. I then reconnected the HDD with exactly the same results.
Since installing the firmware, the only settings that I have changed from default are:
  • Set new username and password
  • Set Local IP
  • Set SSID, Wireless Network Mode and disabled SSID Broadcast
  • Set up Wireless Security
  • Enabled UPnP
  • Set Static Leases for all attached devices
  • Made the USB settings above
How do I get my external USB HDD to mount?
Netgear WNR3500L, DD-WRT Kong Mod USB/FTP/SAMBA3/OpenVPN/Proxy Build 18010M, Win XP Home SP3, Firefox 8, ethernet to GlobeSurfer II modem.
Discussion:    Add a Comment | Comments 1-4 of 4 | Latest Comment
January 17, 2011 12:00 AM updated: January 17, 2011 12:04 AM
Also tried with another external USB HDD, this one FAT formatted. Same result.
Prior to flashing to DD-WRT, the OEM firmware WNR3500L USB port supported HDD's.
It is interesting that the HDD light never comes on now when it is connected to the DD-WRT WNR3500L. It could be a firmware fault or even a hardware fault. The only way for me to test that is to re-flash the OEM firmware.Frown
January 17, 2011 2:43 AM
Hi rbscairns,
see:
http://tips.desipro.de/2010/08/30/usb-drive-not-recognized-wnr3500l/
January 17, 2011 4:28 PM
Thanks for the heads up Kong. Pushing the power button off, waiting 10 seconds, and pushing the power button back on solved the problem.
I owe you a couple of beers if you get to North Queensland, one for your mod and the other for this. I expect I will need more guidance later when I start playing with VPN, so you might be getting a little drunk on me.
January 14, 2012 1:28 PM
I've also had the same problem. I couldn't believe that it's so simple, but.. it worked. Thanks Kong!
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
