Learn about scoring Forum's Raw Score: 3473310.0
January 19, 2011 10:12 AM
Categories: Open Source Projects and Firmware
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
digdug18
Member
I searched, couldn't find a guide or previous post that had a pro versus con of each. I just ordered a WRN3500L from newegg. $64.99 plus free shipping seemed like a good deal to me. I'm looking for something more powerful and stable then the stock system, Please give me your opinion why one is better the the other?
Andrew
Discussion:    Add a Comment | Comments 1-18 of 18 | Latest Comment
January 19, 2011 11:09 AM
TomatoUSB
January 19, 2011 12:20 PM
It basically depends on what you are looking for.
Some choices I can offer you:
Netgear: simple setup, best throughput
Tomato: extended featureset, latest drivers, advanced setup, very good throughput
DD-WRT: extreme featureset, enterprise class monitoring support, good throughput, very stable
Basically you can test all 3 of them since it is easy to switch from netgear to dd-wrt then tomato. If you don't know yet just keep the netgear firmware and see if you are satisfied.
Then you can checkout dd-wrts online demo to see what features you maybe need that are not covered by netgear firmware.
January 19, 2011 12:43 PM
Are their any cons to any of the 3?
January 19, 2011 3:55 PM updated: January 19, 2011 3:57 PM
I think it depends more on what you want to do with your WNR3500L.
I found the Netgeaer OEM firmware to be fast and stable, however it lacked what I wanted. I also wanted my WNR3500L to act as a VPN server (not available with OEM firmware) together with USB support (provided with OEM firmware). Because of that, I installed DD-WRT with USB and OpenVPN support.
I am still learning about setting up OpenVPN with DD-WRT, however I have noticed a significant drop in speed when using DD-WRT -v- OEM firmware. This probably because DD-WRT is more resource intensive due to all the additional available features.
It has been reported that Tomato (also with USB and VPN support) is faster than DD-WRT, but not as fast as the OEM firmware.
Speed is not a major concern for me with my WNR3500L. It is used in a small office network and we charge by the hour. Laughing
Once I lean more about setting up OpenVPN, I might give Tomato a go.
Netgear WNR3500L, DD-WRT Kong Mod USB/FTP/SAMBA3/OpenVPN/Proxy Build 18010M, Win XP Home SP3, Firefox 8, ethernet to GlobeSurfer II modem.
January 19, 2011 8:58 PM
RBSCAIRNS, thanks you, that is exactly what I was looking for.
February 6, 2011 6:42 PM
Has anyone performed any benchmarks with the WRN3500L to see what the speed difference is between the OEM, Tomato, and DD-WRT. I don't need anything major from Tomato or DD-WRT, but I need to run a VPN server, which you can't do with the OEM firmware.
Actiontec MI424WR, Netgear WNDR3700v2, Linksys WRT54GS w/ DD-WRT v24-sp2 std ver. 13064 VINT Eko, Verizon FiOS
February 7, 2011 5:23 AM
anotherlab said: Has anyone performed any benchmarks with the WRN3500L to see what the speed difference is between the OEM, Tomato, and DD-WRT. I don't need anything major from Tomato or DD-WRT, but I need to run a VPN server, which you can't do with the OEM firmware.
I read of some benchmark test results a while ago but cannot reference them now.
Because you need VPN on your router, the OEM firmware will not provide this (as you noted). This leaves you with the choice of DD-WRT or Tomato. From memory, Tomato was slightly faster than DD-WRT, however you would probably not notice the difference.
It is relatively easy to switch between DD-WRT and Tomato and visa versa, so toss a coin, try one, and switch to the other to experience the difference.
February 10, 2011 12:23 PM updated: February 10, 2011 12:29 PM
rbscairns said:I read of some benchmark test results a while ago but cannot reference them now. Because you need VPN on your router, the OEM firmware will not provide this (as you noted). This leaves you with the choice of DD-WRT or Tomato. From memory, Tomato was slightly faster than DD-WRT, however you would probably not notice the difference. It is relatively easy to switch between DD-WRT and Tomato and visa versa, so toss a coin, try one, and switch to the other to experience the difference.
I ended up gettting a WNDR3700v2 (it wasn't much more than the WNR3700) and it turns out that DD-WRT isn't available for it.  OpenWRT supports it, but the installation looked painful.  Since the OEM firmware had everything I needed (except for a pptp server), I just configured my existing DD-WRT router to be an access point and forwarded the pptp port from the 3700 over to the old router.
That appears to be working just fine.  It's a little odd to have an old Linksys router wired up to serve as a pptp server, I can place it on the opposite side of the house and use it as a WAP.
January 16, 2012 2:01 AM
Here is a weird question.
Can you do this?
Use your WNR3500L with OEM firmware and have another Repeater Bridged DD-WRT router WITH OpenVPN setup.
This way you are connected to WNR3500L with OEM firmware and get faster speeds and connect your other equipment such as Roku (I am currently out of the States) to the Repeater bridge router where it needs VPN/OpenVPN.
Did I explain myself?
January 16, 2012 8:19 AM
You should be able to just forward the ports over to the DD-WRT router.
I'm still using the WRT54GS running DD-WRT as wireless access point, but I'm no longer using it for the VPN. I have a Windows Home Server and it was pretty easy to have function it as a VPN. It provides more configurable options and better logging. I'm stilling the OEM firmware on the WNDR3700v2, but I'm considering using something like the Gargoyle firmware to get additional access rules.
January 16, 2012 9:02 AM
I wonder if someone could give instructions on how to do it. I have little knowledge but not this much :)
January 16, 2012 9:27 AM updated: January 16, 2012 9:28 AM
Mico said: I wonder if someone could give instructions on how to do it. I have little knowledge but not this much :)
Which part?  There are several parts to what you have asked.  It sounds like you are asking to do the following:
  1. Install and configure OpenVPN on your DD-WRT router
  2. Configure your DD-WRT as bridged router
  3. Configure your main router to forward VPN requests to your DD-WRT router
I have zero experience with OpenVPN, but there's plenty of information on the DD-WRT site.  I would start with OpenVPN topic in the DD-WRT wiki.  The DD-WRT forums will have additional information.  Also check out How to Configure OpenVPN.
Configuring the DD-WRT as a bridge router is pretty straight forward and I would suggest the Wireless Access Point topic in the DD-WRT wiki.  I have used this to turn my WRT54GS into a WAP.
Redirecting the VPN requests from the main router to the DD-WRT is pretty straight forward.  Just make sure that you have picked the TCP port that you specified when you configured OpenVPN on your DD-WRT router.  The default port number is 1194, but you can specify the port.
When I configured my DD-WRT router as a WAP, I disconnected it from the network and plugged a PC directly into it.  I needed the WAP to be at 192.168.2.2 and it was much easier to configure when I took the other router out of the picture for a bit.
January 16, 2012 9:40 AM updated: January 16, 2012 9:48 AM
anotherlab, I can see your message in my email but it got deleted here I guess.
I just want to know how to do this;
WRT54G with DD-WRT as a repeater bridge with Open VPN settings setup in it.
So, I can use/connect my computers with the WNR3500L and connect my Roku player to the WRT54G.
This way I can do my daily internet stuff faster hence the OEM firmware but also connect my Roku player to DD-WRT repeater bridge to access Netflix, etc. via VPN/OpenVPN.
How can I set it this way???
January 16, 2012 10:01 AM updated: January 16, 2012 12:39 PM
It didn't get deleted, I provided the links to configure the routers and apparently posts with links need to be verified before they appear on here.  Just a security precaution. And it's posted now.
Just a suggestion, make your questions more specific.  I answered as much as I could, but the more specific that you can make the questions, the more likely it will be that someone can help you.
Mico said: anotherlab, I can see your message in my email but it got deleted here I guess. I just want to know how to do this; WNR3500L with OEM firmware WRT54G with DD-WRT as a repeater bridge with Open VPN settings setup in it. So, I can use/connect my computers with the WNR3500L and connect my Roku player to the WRT54G. This way I can do my daily internet stuff faster hence the OEM firmware but also connect my Roku player to DD-WRT repeater bridge to access Netflix, etc. via VPN/OpenVPN. How can I set it this way???
April 17, 2012 7:25 AM
I'm also looking for DD-WRT firmware for TP-Link TD-W8901G Wireless ADSL2+ Modem router, could someone please help to download compatible build for my TP-Link ADSL router.
I need to setup IP v6 support, IP v6 tunnel etc...
April 17, 2012 7:26 AM
I'm also looking for DD-WRT firmware for TP-Link TD-W8901G Wireless ADSL2+ Modem router, could someone please help to download compatible build for my TP-Link router.
April 18, 2012 10:18 AM
sSysAdmin said: I'm also looking for DD-WRT firmware for TP-Link TD-W8901G Wireless ADSL2+ Modem router, could someone please help to download compatible build for my TP-Link router.
You'll probably have better results if you post that kind of question on the DD-WRT web site.  They have a router database that lets you search for your router and see if it's supported.  If it's not listed there, post a message in the DD-WRT forums and see if someone is already working on a build.
April 18, 2012 12:08 PM
Thank you Anotherlab,
I don't see firmware for my routers TP-Link TD-W8901G  and TP-Link TL-WR642G (ver 4.20) and even for LinkSys BEFSX41 models, could someone suggest any alternative Opensource WiFi router firmware for any one of my WiFi routers?
Infact I need IPv6 support and to setup IPv6 tunnels etc...
Discussion:    Add a Comment | Back to Top | Comments 1-18 of 18 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
