Are you using minidlna?
If yes make sure you set the db path to store the db on the usb device otherwise you may run out of memory which can cause this kind of behaviour.
Hi I got the newest Kong-mod installed on my 3500l. So far everything works like a charm except from one stragen behaviour:
After a certain ammount of time (2h to 4h) the web-interface isn´t reachable any more. This is the same for local connections as well as for dyndns. Internet connections outgoing are not affected.
Can sb. help please?
January 20, 2011 9:36 AM
January 21, 2011 4:24 AM
Hi Kong,
thanks for answering. I´m quite new to the topic... Minidlna is running and path is set. So far the problem is solved.
Thanks for your help
RSS
