What OS are you running on your pc that you are running the tests on? If its Windows I've found this TCP Optimizer program over on Speedguide.net pretty useful.
http://www.speedguide.net/downloads.php
Is there a way to get tomato (toastman) to tell me the speed of the ethernet on the wan side.
I've recently upgraded my broadband from "up to 8Mbps" to "up to 20Mbps". I have a tp-link 8816 in bridge mode acting as modem and have a WNR3500L connect to it's lan port. I think I have secured the tp-link (by default it's totally insecure) and the connection seems to be fairly stable.
In the modem web server I can see download speed of around 15Mbs, but testing on my pc I seem to get speeds of only 6Mbs. The WNR3500L & my pc have Gbps ethernet so I'm wondering what speed the tp-link to router cable is actually running at. According to the docs the tp-link is 10/100M, but can I tell what speed is actually used?
Arch linux. I don't think I need optimize the raw speed. I've also tried the speed testing from another machine with windows, but the raw speed seems pretty consistent.
RSS
Well after a couple of days the download speed has increased to 12.5Mbpsso I'm guessing that the td-8816 modem wnr3500L ether is running faster than 10mbps, but I would still like to know if I can determine the ether speeds on the router.
