Learn about scoring Forum's Raw Score: 199046.0
February 14, 2011 11:26 PM
Categories: WGR614L (Legacy Product)
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
OpenMehRouter
Member
I'm quite new to this modding scene so I want to make sure I don't goof anything up.
I read several articles:
http://www.myopenrouter.com/article/10339/DD-WRT-for-NETGEAR-WGR614L-Installation-Guide/
http://www.dd-wrt.com/wiki/index.php/WGR614_v8
http://www.dd-wrt.com/dd-wrtv2/downloads/others/eko/V24_TNG/svn12250/Netgear_readme.txt
And as I understand it I should be able to use the first tutorial as follows...
For first flash (running original Netgear's firmware) or for tftp
please use dd-wrt.v24-12250_NEWD_mini_wgr614v8-L.chk file.
Compatible builds for Netgear routers:
dd-wrt.v24-12250_NEWD_mini.bin
dd-wrt.v24-12250_NEWD_mini_hotspot.bin
dd-wrt.v24-12250_NEWD_std.bin
dd-wrt.v24-12250_NEWD_std-nokaid.bin
dd-wrt.v24-12250_NEWD_std-nokaid_nohotspot_nostor.bin
dd-wrt.v24-12250_NEWD_voip.bin
dd-wrt.v24-12250_NEWD_openvpn_jffs_small.bin
dd-wrt.v24-12250_NEWD_openvpn.bin
The problem is 12250 seems quite dated. So I'm hoping I can get up to snow. Is it ok to... *HARD RESET* followed by...
http://www.dd-wrt.com/dd-wrtv2/downloads/others/eko/V24_TNG/svn12250/dd-wrt.v24-12250_NEWD_mini_wgr614v8-L.chk
and/or:
http://www.dd-wrt.com/dd-wrtv2/downloads/others/eko/V24_TNG/svn15943-snow/dd-wrt.v24-15943_NEWD_mini_wgr614v8-L.chk
http://www.dd-wrt.com/dd-wrtv2/downloads/others/eko/V24_TNG/svn15943-snow/dd-wrt.v24-15943_NEWD_std-nokaid.bin ???
As I understand it this would get me Snow onto my old legacy router. Am I right? If not I certainly don't want to risk bricking the thing, so let me know the safest method to get the latest Standard version of DD-WRT.
Discussion:    Add a Comment | Comments 1-5 of 5 | Latest Comment
February 15, 2011 9:48 AM updated: February 15, 2011 9:55 AM
The downloads section of MyOpenRouter has build 13094 for the initial flash which is the most recent (dated  4-11-10): Link
I supposed one of the newer builds you list may work also but my suggestion would be to stick with the one provided from here since it has been tested enough and then flash to a newer build.
February 18, 2011 7:27 PM
Afraid I ran into a bit of trouble. When I attempt to flash "any" .CHK file it simply states...
Firmware upgrade failed. Please check your file.
Specs:
Hardware Version WGR614V9
Firmware Version V1.2.30_41.0.44NA(does not work with CD version below 2.0)
I tested the initial one you gave (DD-WRT), Tomato 1.25, and an OpenWRT. None work. What now? :(
February 18, 2011 8:03 PM
You have a V9, not a V8. The v9 is not flashable. See the DD-WRT database here.
http://www.dd-wrt.com/site/support/router-database
http://placeshiftingenthusiasts.com/
February 18, 2011 8:11 PM
Ouch. I was under the impression this router was OpenSource...
So does any custom firmware work on this thing? :/
February 19, 2011 10:38 AM
Not that I am aware of .:(
Discussion:    Add a Comment | Back to Top | Comments 1-5 of 5 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
