May 28, 2011 8:39 AM
Dennison said: Striatum. Netgear has told me there is no way to ensure that if any firmware is installed other than Netgear, they cannot guarantee that the factory recovery disk firmware will 100 percent over write any remnants that another 3rd party firmware left behind.
1- It is exactly the same with computers: even if you reformat, you don't erase disk sectors, and you have remnants that can be recovered by specialized softwares... So I can't see what is specific to routers in your question.... All the computers we use are full of ghosts on the disks and they run well !!!
If you want to restore Netgear firmware you just have to erase NVRAM before reverting (it comes back to defaults settings) and there will be no risk of collision between the firmwares. The problem is well known even when upgrading between tho version of the same firmware you sometimes have to erase NVRAM to avoid bugs.
2- There is only one method to be sure that a firmware is installed 100% correctly: it works !!!!!!! I repeat, if the installation is not 100% succesfull, either the firmware is not upgraded (most of the cases) or if you really have no chance the router is bricked.
How do you know that a software is 100% installed ????? It works... What I can't understand is why you are concerned by this problem for router and not for a software, or an OS that you reinstall... It is exactly the same.
And yes if the upload is complete it means that files have been checked and that files have been correctly copied to their destination folders... Upload means 'installation' in that case...So upload = success means installation = success.... If there is a flaw during any part of the process you won't have the success message.
And believe me, I use alternative firmwares since one year, and I can't imagine reverting to stock Netgear software... You should perhaps ask yourself if you really need to burn an opensource firmware, if you are wondering about this sort of problem.
WNR3500L running Toastman's Tomato.
