Learn about scoring Forum's Raw Score: 98972.8
July 7, 2011 10:09 AM
Categories: Troubleshooting
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
rfi
Member
Hello I am using the USB-Serial thing to try to debrick it. I am unable to break to get a CFE prompt at any point, and after the last line of the output it just freezes at nothing and I cant type tftpd etc. Here is the output as I press the "power" button on the router via the COM interface:
CFE for WNR3500L version: v1.0.36
Build Date: Thu Aug 6 15:48:22 CST 2009
Init Arena
Init Devs.
Found a 8MB ST compatible serial flash
et0: Broadcom BCM47XX 10/100/1000 Mbps Ethernet Controller 5.10.56.28
CPU type 0x19740: 453MHz
Tot mem: 65536 KBytes
Device eth0: hwaddr 30-46-9A-9A-0E-F2, ipaddr 192.168.1.1, mask 255.255.255.0
Loading: Failed.
Checksum mismatch:
Image chksum: 0xB94FA4C9
Calc chksum: 0xB6B2D903
Loading: .. 5192 bytes read
Entry at 0x80001000
Closing network.
Discussion:    Add a Comment | Comments 1-2 of 2 | Latest Comment
July 7, 2011 12:15 PM
Update- I had to end up shorting the pins as indicated in another guide on this site, and the COM output indicated a TFTP server had started, so I sent a working .chk and all is well now.
View unverified member's comment - posted by aeg
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
