Learn about scoring Forum's Raw Score: 114282.0
October 26, 2011 02:21 PM
Categories: WNR3500L
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
p-nut
Member
hey guys i need some help, first off i'm completely new to this, so bear with me please.
I have a netgear wnr3500l
I wanted to install a tomato build made specifically for that model router.
here is the tomato build name: tomato-K26USB-1.28.7476MIPSR2-Toastman-RT-Ext
from what i was reading i had to first install dd-wrt, and from there i had to change the tomato extension from .trx to .bin. first thing i did was to change the extension, afterwards i installed dd-wrt. i used a version that was linked on a forum site where someone was asking how to install tomato.
the dd-wrt version i used was this:
dd-wrt.v24-13309_NEWD-2_K2.6_mini-WNR3500L
when i installed dd-wrt everything went fine, i did have to close browser and open it again due to screen going blank every time i tried to save a setting.
after that i upgraded firmware to the tomato build mentioned above.
as soon as i did that the router stopped responding and i only get orange lights. it sends a signal but you cant connect to it, and connecting through lan port gives me nothing.
i read a forumtopic on testignto see if router was bricked.
i connected to the lan port, set my ip the same as the router and pinged it. it said something about time out a few times, and when i turned the router off then back on i was getting a ttl of 100. for a few times then i was getting time out message again
If i understood correctly what i read, that means that  i have to flash dd-wrt trough tftp.
here is the thing i have no idea how to do it, i am currently using a windows 7 computer which apparently gives some trouble, but i also have a windows xp computer that i can do it from.
can you either tell give me an extremely noob friendly step by step one how to fix this router, or link me to such a step by step.
any help is appreciated
Discussion:    Add a Comment | Comments 1-4 of 4 | Latest Comment
October 28, 2011 4:18 PM
http://www.myopenrouter.com/article/16099/How-To-Reflash-Factory-Firmware-on-...
it's differrent model, but you can read more about tftp hack
http://wiki.openwrt.org/toh/netgear/wndr3700
solid orange doesn't sound good
http://www.myopenrouter.com/article/13859/How-To-Debrick-Your-NETGEAR-WNR3500...
http://www.myopenrouter.com/article/20501/Reset-Debrick-NETGEAR-WNR3500L-Pin-...
October 30, 2011 6:59 PM
May be you need reset nvram.hold reset button then power on,wait 30 second ,power off.30s later then power on again.wait 30s then turn off power and release reset button。now,power on wait,it may be ok
November 2, 2011 3:51 PM
thank you for the help i managed to fix it, im getting steady green lights
November 2, 2011 10:05 PM
scratch that now i am getting allthe lights lighting up green, but no internet access whther wireless or connected to tha lan port. when i troubleshoot it with windows i get a message saying that i do not have a valid ip configuration.
also it let me go into the router once, i disconnected from it for one second while i downloaded original router firmware and it didnt give me access again
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
