Learn about scoring Forum's Raw Score: 209802.0
November 10, 2011 02:24 PM
Categories: Troubleshooting
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
Jason97
Member
I read up, I studied up, I knew everything to do, and now not once but twice I've had the same issue with getting this damned tomato firware to work.
I started with a brand new 3500L
Prepped it with a 30/30/30 reset
Installed the suggested build of DD-wrt listed on this sites tomato installation guide
Went off without a hitch, ddwrt installed fine
Did another 30/30/30 reset
During my first try I installed Toastman's http://www.myopenrouter.com/download/26575/Toastman-s-Tomato-Firmware-for-WNR3500L-w-USB-Ext/
and the second time, this latest try: http://www.myopenrouter.com/download/32387/Toastman-Tomato-Firmware/
After I recieve a message that it installed successfully and was complete, I then did another 30/30/30 reset.
And now it comes to this: I turn on my router and I get an orange power light, after about 60 sec the lights flash once, the power led turns green and the wireless light turns on (blue) and then when I try to login it times out or I'm very rarely able to login to the tomato firmware but after about 5 seconds I lose my connection to the router.
I want to love the tomato, but I'm about ready to pull my hair out at this point.
Any help would be greatly appreciated.
Discussion:    Add a Comment | Comments 1-7 of 7 | Latest Comment
November 10, 2011 3:18 PM
toastman firmware has DHCP disable by default .check if you have an fixed ip set to 192.168.1.x on your pc before attempting to connect to router interface.
November 10, 2011 3:39 PM
hobbywan said: toastman firmware has DHCP disable by default .check if you have an fixed ip set to 192.168.1.x on your pc before attempting to connect to router interface.
Okay. I've set up a static IP now. I can actually login to the router for more than 5 seconds at a time. Now the trick is getting to connect to the internet. I have an 2wire modem (att).
What's my next move?
November 11, 2011 2:46 PM
I think you have now the router and the modem on the same network.
U need change the lan adress of the router (or modem) to e.g 192.168.0.1 and change on PC .
ip internet -> modem (192.168.1.1) -> 192.168.1.x (wan) router 192.168.0.1 (lan)-> PC 192.168.0.x.
U can set in the modem a DMZ 192.168.1.x for the router if you don't want to configure too many firewall rules.
November 23, 2011 12:47 PM
I have a similar problem in the fact I can not access after a reset with tomato. My issue is I can't ping the router or even access it through telnet. I'm at a loss as to what to do, did you ever get yours up and running?
November 23, 2011 11:20 PM
Did you tried it with a static IP?
November 24, 2011 10:02 AM
After doing some more searching I was able to set it to a static and gain access.
November 24, 2011 11:40 PM
Its good to know that things are working now.
Discussion:    Add a Comment | Back to Top | Comments 1-7 of 7 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
