Learn about scoring Forum's Raw Score: 496978.0
January 26, 2012 07:01 AM
Categories: WNR3500Lv2 Open Source Router
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
remarke
Member
http://tomato.groov.pl/index.php?dir=K26RT-N%2Fbuild5x-083V%2FWNR3500Lv2
Polish Forum
http://translate.google.pl/translate?sl=pl&tl=en&js=n&prev=_t&hl=pl&ie=UTF-8&layout=2&eotf=1&u=http%3A%2F%2Fopenlinksys.info%2Fforum%2Fviewthread.php%3Fthread_id%3D14035&act=url
Discussion:    Add a Comment | Comments 1-16 of 16 | Latest Comment
January 26, 2012 7:03 AM
Tomato completed. In comparison to the software @ Tathagata, PPPoE works, USB works, running lights and front button
January 26, 2012 7:43 AM
http://www.linksysinfo.org/index.php?threads/let-s-talk-about-netgear-3500l-v...
i also added new download here, but wait for acceptation.
January 26, 2012 4:09 PM updated: January 26, 2012 4:24 PM
nice
January 27, 2012 2:47 AM
as i said:
http://www.myopenrouter.com/download/35232/Tomato-by-Shibby-for-WNR3500Lv2/
January 31, 2012 3:16 PM
Hi shibby, very good work, many thanks. Your firmware is what I was waiting for, since I reflashed I'm able to share 3G internet and printer. No problems with flashing, setup from Tomato initial flash by Tathagata Das not-changed. Thanks again.
February 1, 2012 7:10 AM
Could we have the sources of this firmware please?
February 1, 2012 3:23 PM
Kinda disappointed that Tomato no longer easily compiles on modern Linux, that it pretty much requires some early flavor of Mint, a version which no longer readily accesses updates. Sorta signals the finite shelf-life of this otherwise splendid project, with diminishing development. Kudos to the remaining die-hards that continue to build out this marvel, Tomato.
Been looking forward to Shibby's success at incorporating DNSCrypt should he eventually manage that, as he's previously announced his intentions to do, elsewhere. Courage, coders.
February 2, 2012 2:37 AM
sources are available in git repo:
http://repo.or.cz/w/tomato.git
branch tomato-shibby-RT-N:
http://repo.or.cz/w/tomato.git/shortlog/refs/heads/tomato-shibby-RT-N
February 11, 2012 6:46 AM updated: February 11, 2012 6:50 AM
Excellent.
My brand new WNR3500Lv2 was unboxed yesterday at 16h00, and flashed with this firmware 1 hour later without any problem. Now I have to learn a little on tomato, is my first open router (because I would like to connect a printer and webcam if possible).
For french readers :
Très facile à installer. J'ai téléchargé et décompacté le firmware avec le lien ci dessus, déballé mon routeur, branché sur l'ordi et chargé le firmware directement dans le menu "mise à jour" du routeur. Et ça roule direct.
February 13, 2012 4:33 AM
Printer support is easty to do. Enable Printserver on USB Support page and install new Local printer via TCP/IP port using yuor router ip as TCP/IP port.
About webcam you will need extra modules. You can find it here:
http://tomato.groov.pl/K26RT-N/build5x-083V/extras-mips2.tar.gz
Only cameras supported by UVC drivers will work.
February 13, 2012 7:18 PM updated: February 13, 2012 8:18 PM
Hi, after install this to my WNR3500Lv2 I cannot get any IP adress from the router.
What can I do? The upgrade process seemed to work. I did saw a new interface. But when I updated the page I couldn´t access it.
Help! :)
EDIT: Works now: Did 30-30-30.. :)
February 14, 2012 8:16 AM
You can find it here: http://tomato.groov.pl/K26RT-N/build5x-083V/extras-mips2.tar.gz Only cameras supported by UVC drivers will work.
Thank you for your help ! I've tried :
cd /mnt/USB_DISK/opt/extra/
insmod videodev.ko
insmod v4l2-common.ko
insmod v4l2-int-device.ko
insmod input-core.ko
insmod uvcvideo.ko
but my Philips SPC 900NC seems not work with UVC driver...
usb 1-1.1: USB disconnect, address 6
usb 1-1.2: new full speed USB device using ehci_hcd and address 7
usb 1-1.2: configuration #1 chosen from 1 choice
Perhaps I need to buy a new webcam in the http://www.ideasonboard.org/uvc/ list :-)
View unverified member's comment - posted by deedee
February 18, 2012 10:12 AM
Does it runs on old wrn3500l?
February 18, 2012 10:47 AM
3500lv2 and 3500l use different program
April 19, 2012 1:08 PM
DNSCrypt is now functional in Tomato. Shibby, you rock!
Discussion:    Add a Comment | Back to Top | Comments 1-16 of 16 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
