Learn about scoring Forum's Raw Score: 865201.0
January 30, 2012 08:19 PM
Categories: WNR3500L
Rating (1 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
gvest
Member
help: how to distinguish 3500L V1 or V2
In the router status, it shows below message:
hardware     WNR3500L
firmware     V1.2.2.44_35.0.53NA
so it is 3500L V1 or 3500L V2?
thanks
Discussion:    Add a Comment | Comments 1-18 of 18 | Latest Comment
January 30, 2012 10:50 PM
You can find the name of the router (Model: WNR3500Lv2) at the front side (same side where you can find the power port) of the router.
January 31, 2012 1:30 AM
thank you very much
January 31, 2012 7:57 PM
As Tathagata said, I only found WNR3500L at the front side, so now I can confirm my router is version V1, thanks to Tathagata.
And I think this kind of topic should be set to top, for I found serveral newbee like me ask this question. So it should set to top or wirte in FAQ.
February 1, 2012 1:33 AM updated: February 1, 2012 1:36 AM
Good to know that you are able to recognise your router.
Hope, the following two pictures will provide more information to the newbee,
WNR3500L :-
WNR3500Lv2 :-
February 18, 2012 1:52 PM
Anyone know if Amazon is shipping v1 or v2 of the WNR3500L now?
February 20, 2012 11:59 PM
RolandGunner said: Anyone know if Amazon is shipping v1 or v2 of the WNR3500L now?
Most probably yes.
February 21, 2012 9:30 PM
Alas, not necessarily. Ordered yesterday, arrived today and it's a v1. Not a big deal, I suppose it will do just fine.
February 22, 2012 1:35 AM
Main difference between V1 and V2 is memory capacity. Otherwise they are quite similar.
March 1, 2012 5:43 PM
I have the Sam Knows supplied wnr3500u/wnr3500l, apparently v1, although it has the n300 label next to the model # as in the second picture.
Do you know, does this have special firmware for their program or can I use Tomato or something similar?
Current firmware version is V1.2.2.26_33.0.28SK
March 1, 2012 11:55 PM
Can you please post some picture of your router so that I can have clear idea about the model ??
March 2, 2012 1:43 PM
Here's a poor-quality photo:
March 5, 2012 12:39 AM updated: March 5, 2012 12:40 AM
Merely viewing this picture I guess it is wnr3500Lv1. Can you please give a snapshot of your router's boot-log ??
May 22, 2012 12:58 PM
dolo724 said: I have the Sam Knows supplied wnr3500u/wnr3500l, apparently v1, although it has the n300 label next to the model # as in the second picture. Do you know, does this have special firmware for their program or can I use Tomato or something similar? Current firmware version is V1.2.2.26_33.0.28SK Thanks!
did you get an answer to this?
May 22, 2012 2:12 PM
pietro said:   did you get an answer to this?
No.
It's been a while since I have been able to look at this problem, and I've decided to stick with the OEM for now. Also, I don't have a serial port so I don't have a simple method of getting the boot log as requested.
May 22, 2012 2:18 PM
This is working for me
http://www.myopenrouter.com/download/19806/DD-WRT-Kong-Mod-USB-FTP-miniDLNA-Samba3-WNR3500Lv1/
May 22, 2012 5:02 PM
pietro said:  This is working for me http://www.myopenrouter.com/download/19806/DD-WRT-Kong-Mod-USB-FTP-miniDLNA-Samba3-WNR3500Lv1/
I'll give this a shot later and post back here with success. If I have problems, I'll start a new thread.
And to answer an earlier question, I do have the wnr3500L v1.
May 24, 2012 2:00 PM
Subhra said: Good to know that you are able to recognise your router. Hope, the following two pictures will provide more information to the newbee, WNR3500L :- WNR3500Lv2 :-
Thank you so much!
May 25, 2012 11:49 PM updated: May 25, 2012 11:49 PM
See this article ... it contains more compact information.
Discussion:    Add a Comment | Back to Top | Comments 1-18 of 18 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
