Learn about scoring Forum's Raw Score: 244565.0
February 19, 2012 07:33 PM
Categories: Troubleshooting
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
strickman75
Member
I have had the 3500L for over a year now and I love it. In November I bought a new laptop and it connected to my router no problem at 150Mbps and ran like that for some time. Just recently I noticed that it was only connecting at 72Mbps, so I thought I'd buy a better quality usb adapter thinking there was a problem with the one in the laptop, but its only connecting at less then half of what it should. I checked in the router settings and its set to connect at 300Mbps. so my questions is, is there anything else I should check or do? any ideas or suggestions would be very helpful.
Discussion:    Add a Comment | Comments 1-5 of 5 | Latest Comment
February 19, 2012 11:52 PM
Is there any other AP running nearby ??
You can try by setting it to a different channel.
February 20, 2012 11:48 PM
I guess there are some other APs in the vicinity with same channel. Can you change the channel of the router ?
Also did you change your wireless client adapter ?
February 21, 2012 5:31 AM
Thank you for the responces it was a big help.
February 21, 2012 7:27 AM
What about your problem with connection speed ? Is it solved ?
May 13, 2012 9:47 AM
You generally only get 1/2 of your connection speed since the 'hardware' is rated
in a DUPLEX mode and an up-load test is only SIMPLEX or one-way...
Discussion:    Add a Comment | Back to Top | Comments 1-5 of 5 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
