Thanks Subhra for preparing such a nice document. However I have following comment on this article.
Step 1. It would be better if you specify the path from where toolchain is available.
I think step 6 and 7 are required only when we use Fedora Core 14 or higher version of Fedora Core 14.
Step 8: It would be nice if you can give example.
Step 9: Clean may not be necessary for first compilation but it is necessary for next time compilation. So the command would be
"make -f Makefile.wnr3500lv2 configure clean all install"
Categories: WNR3500Lv2 Open Source Router
Hi all,
I have seen that many people are facing problems in building DDWRT firmware for WNR3500Lv2. I have been able to build it. Here I am sharing the steps I followed to perform the same.
[NOTE:- This method requires to have both 32-bit and 64-bit machine.]
Step 1: Download toolchain to compile ddwrt.
Step 2: Perform the following modification in "toolchain-mipsel_gcc4.1.2/mipsel-linux-uclibc/sys-include/regex.h" file in toolchain.
Original Code :-
#if !defined _POSIX_C_SOURCE && !defined _POSIX_SOURCE && defined VMS
/* VMS doesn't have `size_t' in , even though POSIX says it
should be there. */
# include <stddef.h>
#endif
Modified Code :-
should be there. */
#endif
Step 3: Download "DD-WRT Source Code (Used in WNR3500Lv2 Firmware Build)" from this link and untar it using following command,
$ tar -zxvf dd-wrt.tgz
Step 4: Download the "DD-WRT for WNR3500Lv2 Initial Release 1.0" from this link.
Step 5: Untar "DDWRT_WNR3500Lv2_Final_Release_09-12-2011.tgz" using following command,
$ unzip DDWRT_WNR3500Lv2_Final_Release_09-12-2011.tgz.zip
$ tar -zxvf DDWRT_WNR3500Lv2_Final_Release_09-12-2011.tgz
Go to DDWRT_WNR3500Lv2_Final_Release_09-12-2011 using following command,
$ cd DDWRT_WNR3500Lv2_Final_Release_09-12-2011
Make DD-WRT source code ready for Netgear WNR3500Lv2 using the following command,
$ sh ddwrt_build_wnr3500lv2.sh
Step 6: Perform the following modification the "dd-wrt/src/router/rules/pppoe.mk" file
Original Code:-
pppoe pppoe-%:
@true
Modifed Code:-
pppoe-%:
@true
Step 7: Perform the follwoing modifiaction the "dd-wrt/src/router/busybox/Makefile" file
Line 421:-
Original Code:-
config %config: scripts_basic outputmakefile FORCE
$(Q)mkdir -p include
Modifed Code:-
Line 1273:-
Original Code:-
/ %/: prepare scripts FORCE
$(Q)$(MAKE) KBUILD_MODULES=$(if $(CONFIG_MODULES),1) \
Modified Code:-
Step 8: Export toolchain path.
Step 9: Go to "dd-wrt/src/router".
Step 10: Use the following command to compile the source code,
"make -f Makefile.wnr3500lv2 configure all install"
[Note: This step should be performed in a 64-bit machine. I have used Fedora Core 15 for this purpose.]
Step 11: After successful compilation download following utility and use these series of commands,
[Note: These steps should be performed in a 32-bit machine. I have used Fedora Core 14 for this purpose.]
$ tar -zxvf DD-WRT_Image_Creation.tgz
$ cd DD-WRT_Image_Creation
$ sh ddwrt_image.sh
If everything goes well you should find the firmware ("ddwrt-wnr3500lv2.chk") in same ("DD-WRT_Image_Creation") directory.
@Tathagata: Thank you for pointing out the shortcoming of this document.
Step 1:
Toolchain can be downloaded from this link.
Step 8:
Use the following command to export your toolchain path.
export PATH=/TOOLCAHIN_BASE_PATH/toolchain-mipsel_gcc4.1.2/bin:$PATH
In my case I have downloaded the toolchain in "/opt" so for me the command was ,
export PATH=/opt/toolchain-mipsel_gcc4.1.2/bin:$PATH
Step 10:-
For compiling first time use the command,
and for further compilation use following command,
Fisrt, thank you for your post. I would like to know which is differences between DDWRT_WNR3500Lv2_Final_Release_09-12-2011 and the firmware that I can make with your post and code source ?
And, for the Linux distribution, can I use Debian 6 (32 and 64) ?
Thank you
The sample firmware supplied with the "DDWRT_WNR3500Lv2_Final_Release_09-12-2011" and the firmware generated by the above procedure would be same.
Theoretically Debian may be used for the compilation provided all basic development tools are installed. But I personally never did the same.
New dd-wrt for WNR3500Lv2 is released. It needs just one 64 bit machine to compile the firmware. You will find this build here.
RSS
