Learn about scoring Forum's Raw Score: 129746.0
February 21, 2012 11:14 PM
Categories: DD-WRT
Rating (0 votes)
  • 1
  • 2
  • 3
  • 4
  • 5
Rate This!
Member Avatar
silvery
Member
Hi. After lastest Optware update on my WNR3500L with DD-WRT (dd-wrt.v24-14896_NEWD-2_K2.6_big.bin) I have a problem with using GREP command, it gives me an error:
grep: can't load library 'libpcre.so.0'
Does anyone faced the issues?
Discussion:    Add a Comment | Comments 1-6 of 6 | Latest Comment
February 21, 2012 11:19 PM
The following package was installed right before this problem appeared:
Package pcre (8.30-1)
February 22, 2012 4:22 AM
I also have this problem on an Asus RT-N16 after running ipkg-opt update/ipkg-opt upgrade. Have you tried rebooting the router?
February 22, 2012 4:51 AM
Found a simple solution. It seems that the upgrade removes libpcre.so.0 and replace it with libpcre.so.1
A working solution is to create a symbolic link in /opt/lib by running the command: ln -s libpcre.so.1 libpcre.so.0 in that directory
February 22, 2012 1:50 PM
wabe said: Found a simple solution. It seems that the upgrade removes libpcre.so.0 and replace it with libpcre.so.1 A working solution is to create a symbolic link in /opt/lib by running the command: ln -s libpcre.so.1 libpcre.so.0 in that directory
Thank you so much!
February 24, 2012 1:31 AM
Seems a great solution, many thanks!
I was already thought that I would have to compile the lybrary by myself... maybe next time then)).
I also noticed that external HDD mounts on /opt only and my /mnt partition is clear. Tonight i'm going to figure out if it's hardware problems, but it starts at the same moment with grep problem, so I think you may have some right direction to start with, thanks in advance.
February 24, 2012 1:48 AM
Fixed with reboot after ln -s libpcre.so.1 libpcre.so.0, so I finally got all back. And again: thanks wabe!
Discussion:    Add a Comment | Back to Top | Comments 1-6 of 6 | Latest Comment
Add Your Reply
(will not be displayed)
Log In
Remember
Not a member? Sign up!
Did you forget your password?
close this window
close this window
