Yes you can re-flash with Stock firmware from WebUI firmware upgrade option.
BTW which firmware you were using???
Categories: Setup/Configuration
Since I'm not able to run my PPTP server on this router, I will probably return it to the store.
Is It possible the reflash it with stock firmware?
Ben
I google for how to get back to the stock firmware, all tutorials point out a TTL cable is required or u r able to run the "erase" program in DDWRT ROM which the Tomato do not have. At last, I just update the firmware in the Tomatos' upgrade page,following 30-30-30 rest, it just works, and my router is running the stock firmware correctly now. wish this do help..
Tomato Initial release enables you to upgrade stock firmware directly from the WebUI via firmware upgrade option.But I am not sure if the same is true for Shibby's,Tostman's or other firmwares or not.
RSS
