Proto: TCP/UDP Ext port: 8081 Int port: 8081 Int address: 192.168.1.???
Then hit " Save" and it should work.
Connect with: http://wanip:8081
Categories: Setup/Configuration
Hi, I installed Tomato by Shibby on my Netgear WNR3500Lv2.
I've no problem with connection, but I can't connect my ipcamera, by a public ip(remote).
I made a port forwarding on 8081 port (TCP/UDP), but not work.
Where I wrong?
Thanks for help
Okey, there is a lateset one 097 if you wan't upgrade. Don't forget to do a NVRAM reset before and after upgrading.
Make sure you using static ip for your portforwarding.
Ehm can you connect inside your LAN then ?
I'm using PF and have no problem. Don't know why not working for you.
kthaddock
Hi, i've the same problem. Something is wrong with port forwarding in this tomato. After many, many tests and restarts, hard resets, clearing nvram one range of ports is working, but others still no.
Did you forget your password?
