hrm, which build number are you using on that unit? also, are wl0 and wl0.1's MAC address the same? Can check by looking in Wireless > Basic Settings, if they are, its going to be quite hard to hide it.
Hi, I have a Linksys wrt54gs v2.1 with DD-WRT v24-sp2 it's set up as a repeater. I want to hide the SSID of the virtual interface wl01 which is dd-wrt_vap, I selected Disable for Wireless SSID Broadcast in the menu and saved, applied settings and rebooted the unit. But it still shows up on all wifi remote interfaces, but I want it to be hidden. I turned off the repeater to "rest" it. Rebooted remote PCs. Still shows as a visiable SSID. How do I do this? Thanks
August 10, 2012 8:58 PM
RSS
