There is. WGR614v9 is almost similar to WGR614v8 but it has only 2MB of flash and usually not enough to run most open source replacement firmwares. Of course there are some firmwares that may work with this limited flash. I am not sure but it is likely that SDRAM is also lower there.
-- Nachi
Categories: WGR614L Open Source Router
Can anyone tell me if there is a difference between the v8/L and the v9?
Click here to see the BC Blog Do you own a Sansa MP3 Player? Then Click here to check out the SansaCommunity!
May 3, 2008 2:12 PM
RSS
