Have you been wondering what the differences between the V1 & V2 versions of the R6200 and R6300 models are?
Here is a quick cheat sheet that provides the specifications.
R6300 |
R6200 |
V1 |
V2 |
V1 |
V2 |
CPU |
BCM4706 600MHz Single Core |
BCM4708 800MHz Dual Core |
BCM 4718 500MHz Single Core |
BCM47081 800MHz Single Core |
USB Ports |
2x USB2.0 |
1x USB3.0 1x USB2.0 |
1x USB2.0 |
1x USB3.0 |
Memory |
128MB |
256MB |
128MB |
256MB |
There are some nice improvements in the V2 models across the board.
Category:
One thing you forgot. The R6300 V2 also has 128MB of flash memory as well as the 256MB of ram shown here.
Very handy material, thanks for posting this.
Is there an easy way to determine which model I have.
dbx8 - On the 6300, just look at the USB ports, if both of them are black, they are both 2.0 which makes it a v1, 3.0 ports are blue. Same thing with the 6200 if that is the one you have. Not the most technical way of knowing, but it is the easiest without having to go into the details of it through software.
