How to build DD-WRT Build for the R7000 Router
If you would like to build your own version of DD-WRT for Netgear's R7000 Router here are the basic steps.
Prerequisites
  • A 32-bit Linux machine (I use Fedora 14)
  • DD-WRT source code of R7000 ( Download here) Download Size:760578127 bytes (725.34MB)
  • Toolchain to compile DD-WRT source code (Use the same toolchain that is used for compiling the stock source code).
  • Compilation should be done as root user.
Steps
1. Create a directory path for toolchain.
  • mkdir -p /projects/hnd/tools/linux/
2. Copy toolchain to that directory.
  • cp hndtools-arm-linux-2.6.36-uclibc-4.5.3.tar.bz2 /projects/hnd/tools/linux/
3. Decompress toolchain.
  • cd /projects/hnd/tools/linux/
  • tar -jxvf hndtools-arm-linux-2.6.36-uclibc-4.5.3.tar.bz2
4. Comment out the definition
  • "typedef float float_t;" in the file "hndtools-arm-linux-2.6.36-uclibc-4.5.3/arm-brcm-linux-uclibcgnueabi/sysroot/usr/include/bits/mathdef.h"
5. Export toolchain path.
  • export PATH=/projects/hnd/tools/linux/hndtools-arm-linux-2.6.36-uclibc-4.5.3/bin/:$PATH
6. Decompress DD-WRT source code.
  • tar -zxvf dd-wrt_R7000_2-Sep-2013.tgz
7. Select configuration file.
  • cd dd-wrt/src/router
  • cp .config_R7000 .config
8. Compile the source code.
  • make -f Makefile.brcm_arm configure clean all install
On successful compilation, DD-WRT firmware of Negear R7000 will be created.
  • Filename: "dd-wrt.v24-K26_R7000.chk"
  • Path: "dd-wrt/src/router/arm-uclib
Tags:
steve3268
steve3268's picture
very well written, Thanks
very well written, Thanks again for your help on my build before kudos!!!!
Dion Houston Sr.
Dion Houston Sr.'s picture
OK, sorry if this is a real
OK, sorry if this is a real easy question - I've tried to find hndtools-arm-linux-2.6.36-uclibc-4.5.3.tar.bz2 through Google, various websites (NetGear, DDWRT, etc.). The closest I've gotten is here [1] which looks promising, but the files in the bin directory don't appear to work unless I'm missing something (I get no such file or directory even though I used auto-complete, and I did confirm it's +x).
Can you tell me where I can the tool chain from? Thanks!
[1] https://github.com/RMerl/asuswrt-merlin/tree/master/release/src-rt-6.x.4...
Subhra
Subhra's picture
I have used same toolchain
I have used same toolchain that i have used for R6250. I got this toolchain along with the R6250 source code from Netgear Website.
doobie
doobie's picture
I have tried to build the image based on the toolchain from Netgear website (from R6300 src package). The build went gave an error with ccache (later I installed), some tmp creation error (also fixed) and trx path not found.
I found there are two trx one is under router/netgear/brcm-arm and the other is under router/netgear. I add the PATH for brcm-arm and the trx package gave me error and of course, the built image bricked the router (recoverable by console and tftpd).
Could you give me some pointers? I used ubuntu 12.04T 32bit server ... (tried Fedora, but not able to get ccache rpm to install, gaved up).
Thanks so very much for your help!
doob
Subhra
Subhra's picture
I have already mentioned that
I have already mentioned that I have used toolchain included with R6250 source. Why are you using toolchain included for R6300 source ?? Is there any specific reason behind that ??
easyhorpak
easyhorpak's picture
Hi
Hi
I got this error how to solve it.
cd dropbear && ./configure --host=arm-linux --disable-lastlog --disable-utmp --disable-utmpx --disable-wtmp --disable-wtmpx --disable-libutil CC="ccache arm-brcm-linux-uclibcgnueabi-gcc" CFLAGS="-I../zlib -Os -pipe -fno-caller-saves -L../zlib -ffunction-sections -fdata-sections -Wl,--gc-sections" LDFLAGS="-L../zlib -ffunction-sections -fdata-sections -Wl,--gc-sections" host_alias=arm-linux
configure: WARNING: If you wanted to set the --build type, don't use --host.
    If a cross compiler is detected then cross compile mode will be used.
checking for arm-linux-gcc... ccache arm-brcm-linux-uclibcgnueabi-gcc
checking for C compiler default output file name...
configure: error: C compiler cannot create executables
See `config.log' for more details.
make: *** [dropbear-configure] Error 77
easyhorpak
on Ubuntu 14.04
on Ubuntu 14.04
This error resolve by
apt-get install ccache
next error
cat not create /root/tmp
resolve by
mkdir /root/tmp
chmod 777 /root/tmp
easyhorpak
Next error
Next error
#Creating linux.trx
#./netgear/brcm-arm/trx -o arm-uclibc/linux.trx arm-uclibc/vmlinuz arm-uclibc/target.squashfs
make: trx: Command not found
make: *** [install] Error 127
resolve by
cd dd-wrt/src/router/netgear/brcm-arm
ln -s $(pwd)/trx /usr/bin/trx
Build success OH GODDDDDDDDDDDDDD !!
easyhorpak
Bad news
Bad news
file dd-wrt.v24-K26_R7000.chk just 7.2mb
I upload to R7000 and it bricked my R7000.
I WILL BE BACK ....
ccyeh
ccyeh's picture
I also meet this problem.
Do you know how to fix it?
ccyeh
ccyeh's picture
ccyeh
ccyeh's picture
joelimome
joelimome's picture
Where can I download  the
Where can I download  the toolchain hndtools-arm-linux-2.6.36-uclibc-4.5.3.tar.bz2
