Quick Review and Specifications: NETGEAR R6200 Wireless 802.11ac High Speed Router
The NETGEAR R6200 WiFi Router delivers next generation WiFi speeds. 802.11ac technology offers better range for mobile devices with speeds up to 867 Mbps.
Compatible with next generation WiFi devices and backward compatible with 802.11 a/b/g/n devices, it enables HD streaming throughout your home. With up to 300+867 Mbps† speed and simultaneous dual band technology, the R6200 avoids interference, ensuring top WiFi speeds and reliable connections. This makes it ideal for larger homes with multiple devices. In addition, four Gigabit Ethernet ports offer ultra-fast wired connections. Wirelessly access and share USB hard drive or USB printer using the USB 2.0 port.
The NETGEAR genie® app provides easy installation from an iPad®, tablet, computer or smartphone. It includes a personal dashboard, allowing you to monitor, control and repair your home network.
Features of the R6200 802.11ac Wireless Router
  • NEXT GENERATION WIFI—300/867 Mbps speeds
  • GIGABIT WIRED — Ideal for HD gaming & video
  • SIMULTANEOUS DUAL BAND — Reduces interference for better connections to more WiFi devices
  • DLNA® — Find & play your media on DLNA TVs & game consoles
  • ReadySHARE® USB ACCESS — Wirelessly access & share USB hard drives
  • ReadySHARE® Printer — Wirelessly access & share a USB printer
  • ULTIMATE RANGE — WiFi coverage throughout your home
  • EASY INSTALL — Easy setup for iPad®, tablets, smartphones & computers
  • NETGEAR GENIE® APP — Personal dashboard to monitor, control & repair your home network
  • PUSH ‘N’ CONNECT — Secure push button WiFi connections (WPS)
  • WIFI & POWER ON/OFF — Convenient power savings
  • PARENTAL CONTROLS — Web filtering for all your connected devices
  • GUEST NETWORK ACCESS — Separate & secure access for guests
  • SECURE WIFI CONNECTIONS — Highest level wireless security with WPA/WPA2
Performance Features
  • WiFi Boost with high-powered radio amplifiers
  • Memory: 16 MB flash and 128 MB RAM
  • Advanced Quality of Service (QoS)
  • IPv6 Support (Internet Protocol Version 6)
Tags:
jl22182
Are there any plan to make dd
Are there any plan to make dd-wrt version to R6200.
