Quick Review and Specs: NETGEAR WNDR4000 Wireless Dual Band Gigabit Router
The NETGEAR N750 Wireless Dual Band Gigabit Router offers high performance wireless speeds of up to 450 Mbps needed for demanding applications, such as large file transfers, streaming HD video and multiplayer gaming. Dual band technology avoids interference, ensuring top speeds and the highest range, while Gigabit offers ultra-fast wired connections.
  • Faster multimedia streaming — Provides up to 450 Mbps wireless speed for streaming HD videos, simultaneous downloads, and online gaming in addition to basic Internet applications.
  • Simultaneous Dual band — Ensures top speeds and avoids interference for better wireless connections
  • Ultra-fast wired — Four Gigabit Ethernet ports deliver ultra-fast wired connections for gaming and video
  • ReadySHARE® USB — Easy shared access to an external USB storage device
  • Live Parental Controls — Keeps your Internet experience safe using flexible and customizable filter settings
  • Guest network access — Provides separate security and access restrictions for guests using the network
  • Broadband usage meter — Monitors Internet traffic and sends customized reports to help keep costs under control
  • Easy setup — NETGEAR Genie™ with graphical installation guide and multi-language support
  • Secured connection — Push 'N' Connect ensures a quick and secure network connection
  • NETGEAR Green features — Power and Wi-Fi on/off buttons to save energy when not in use and 80% recycled packaging
WNDR4000 Specifications
Package Contents
  • N750 Wireless Dual Band Gigabit Router (WNDR4000)
  • Stand
  • Ethernet cable
  • NETGEAR Genie™ installation CD
  • Power adapter, localized to country of sale
Advanced Features
  • Live Parental Controls with flexible and customizable filter settings
  • Simultaneous Dual Band—2.4 GHz and 5 GHz operation
  • ReadySHARE® USB Storage Access—supports FAT16/32, NTFS Read/Write, Ext 2 Read/Write, Ext 3 Read/Write
  • Multiple SSID guest networks (separate security and access restrictions)
  • Broadband usage meter measures Internet usage
  • Power and Wi-Fi on/off buttons
Physical Specifications
  • Dimensions: 223 x 153 x 31 mm (8.8 x 6.0 x 1.2 in)
  • Weight: 0.5 kg (1.2 lb)
Warranty
  • Localized to country of sale
System Requirements
  • Broadband (cable, DSL) Internet service and modem with Ethernet connection
  • 2.4 or 5.0 GHz 802.11a/b/g/n specification wireless adapter or an Ethernet adapter and cable for each computer
  • Microsoft® Windows 7, Vista®, XP®, 2000, Mac OS®, UNIX®, or Linux®
  • Microsoft® Internet Explorer® 5.0, Firefox® 2.0 or Safari 1.4 or higher
  • Use a laptop with built-in Centrino6300 wireless for maximum performance
  • Use with an N600 Wireless Dual Band USB Adapter (WNDA3100)—optional
Standards
  • IEEE® 802.11 b/g/n 2.4 GHz
  • IEEE 802.11 a/n 5.0 GHz
  • Five (5) 10/100/1000 (1 WAN and 4 LAN) Gigabit Ethernet ports with auto-sensing technology
  • IPv6 Support (Internet Protocol Version 6)
Performance
  • Memory: 8 MB flash and 64 MB RAM
  • Five (5) (1 WAN, 4 LAN) Gigabit Ethernet ports
  • Advanced Quality of Service (QoS)
  • Supports Wireless Multimedia (WMM) based QoS
Security
  • Wi-Fi Protected Access® (WPA/WPA2—PSK) and WEP
  • Double firewall protection (SPI and NAT firewall)
  • Denial-of-service (DoS) attack prevention
Ease of Use
  • Push 'N' Connect using Wi-Fi Protected Setup® (WPS)1
[Shop for NETGEAR Products]
[More information at NETGEAR's Official Site]
yousaf465
No printer sharing ?? No
No printer sharing ?? No double USB ? 8Mb flash ?
