Review and Description of the Broadcom BCM5354 Chipset
The BCM5354 achieves the lowest cost and highest performance router system-on-chip (SoC) integration for residential and small office, home office (SOHO) markets OPTIMIZED 802.11G ROUTER WITH BROADRANGE FEATURES.
  • It comes with 240-MHz MIPS32В® CPU core with 16-KB instruction cache, 16-KB data cache, and 1-KB prefetch cache
  • Memory Management Unit (MMU) for high-level Real-Time Operating System (RTOS) support
  • 2.4-GHz direct conversion radio.
  • USB 2.0 host controller
  • SDRAM controller - 16-bit, 120-MHz SDRAM controller
  • SDR and DDR support
  • USB host interface allows for platform expansion by end users and can support USB print server or Microsoft WindowsВ® Connect Now functionality
  • Supports serial flash
  • Supports high-speed performance mode (HSM) of 125 Mbps that is backward compatible with standard 802.11 b/g Five-port integrated 10/100BASE-TX/FX IEEE 802.3u
  • compliant Auto-MDIX transceivers and LAN/WAN switch
  • Signal processing technology enhances receive controller sensitivity resulting in excellent wireless throughput and range in a home and business environment
  • Eight GPIOs for attachment to various external devices (example: LEDs)
  • One JTAG and two UART ports for debugging development and attaching Data Terminal Equipment (DTE)
  • Low Cost 802.11g Router Flash BCM5354 802.11b/g MAC/PHY/ Radio + Switch DDR/SDR SDRAM Five-Port Magnetics Four-Port LAN 10/100 RJ-45 WAN 10/100 RJ-45 OVERVIEW USB 2.0 Host 1 MB-32MB Flash 2 MB-128MB 120 Mhz DDR/SDR SDRAM 802.11 b/g MAC/PHY/Radio Encore DSP 16 KB I-Cache 16 KB D-Cache PLL GPIO Flash I/F SDRAM I/F 240-MHz MIPS32 with MMU JTAG UART Low-Cost Five-Port Switch 10/100 MAC/PHY System Block Diagram The BCM5354 integrates a high-performance MIPS32 processor, IEEE 802.11 b/g MAC/PHY, 2.4-GHz direct conversion radio, USB 2.0 host controller, SDRAM controller, and a configurable five-port Fast Ethernet (FE) switch. The BCM5354 provides wireless LAN connectivity that supports data rates of up to 125 Mbps that is backward-compatible with standard 802.11 b/g. The BCM5354 supports a WAN connection via its configurable media interfaces. The per-port programmable four-level priority queues enable QoS (IEEE 802.1p) for guaranteed bandwidth applications, DiffServ/ TOS, and L2/L3 IGMP snooping. The IEEE 802.1Q VLAN allows flexible implementation of VLAN grouping and WAN port segregation. Applications running on the BCM5354 leverage field-proven software which includes SecureEasySetupв
  • Comprehensive wireless network security support that comprises WEP/WPA/WPA2 encryption. The BCM5354 offers industry's most aggressive home router integration and enables the lowest bill of materials (BOM) solution cost.
thomas
Could some one post the
Could some one post the BCM5354 data sheet/AN ?
