Want to learn the tomato source
8 posts / 0 new
sarmi
Hi all,
I am very interested about the tomato firmware and like to understand  the source base. Can anybody please help me out regarding this?
I have already checked the blogs in this site. Thanks to Tathagata Das, I will download the source and try to compile it as mentioned in the blogs. I hope compilation will be through. Please let me know about the source code organization and from where to start.
Thanks in advance.
sarmi
I am searching for the code
I am searching for the code of wireless and ethernet in drivers/net. But there is no code. where should I look for that?
mona
I have also downloaded the
I have also downloaded the code... With this code every time I need to flash the image. Is there any other option which can reduce the debugging time?
SouvikGhosh
you can run a image from RAM
you can run a image from RAM also.... for that you need to set one nvram variables.
1. Get into the CFE prompt. Execute the following commands -
'nvram set boot_wait=on'
'nvram commit'
2. reboot the router. Now the router will search for vmlinuz from 192.168.1.2.
3. So connect a host in the router's LAN side and set it's IP to 192.168.1.2
3. Run tftp server in this machine and place your vmlinuz in the /tftpboot folder.
Now the router will boot from vmlinuz file placed in 192.168.1.2
mona
Thank you. This procedure is
Thank you. This procedure is really helpful.
sarmi
Could you please tell me what
Could you please tell me what is nvram? Is it necessary to assign the
host ip address 192.168.1.2? I have tried with other ip address. But
its not working. It is only working when host ip address is set to
192.168.1.2.
kaustab
Hi
Hi
I want to know about the steps we need to perform to boot the wgr614l board from flash. Will you tell me?
SouvikGhosh
Non-volatile random access
Non-volatile random access memory (NVRAM) is the general name used to describe any type of random access memory which does not lose its information when power is turned off.
To boot the image from flash you must set the host ip to 192.168.1.2. Because when the boot_wait os set to on, by default CFE searchs for vmlinuz from 192.168.1.2 and if it does not find anything then boots the flash image. So you need to assign this ip to the board if wish to boot from RAM.
