Tomato WPA2 problem
18 posts / 0 new
kaustab
kaustab's picture
Tomato WPA2 problem
Hi all,
I have downloaded the tomato firmware from this site. WPA-PASK and WPA2-PSK is not working in this firmware. I have downloaded the code also like to debug this problem. Can anybody please inform me where to start with?
SouvikGhosh
SouvikGhosh's picture
The problem lies in the
The problem lies in the wlconf tool. wlconf can not set the psk to the driver successfully. This ioctl returns -1. The wlconf source is located in the 'src/router/wlconf' directory. check the wlconf routine in wlconf.c.
kaustab
kaustab's picture
Thanks for the quick reply.
Thanks for the quick reply. Things are not still very clear to me. Can you please elaborate the mechanism.
SouvikGhosh
when you save any
when you save any configuration from UI, cgi sets different nvram attributes according to the value you changed and starts the wlconf tool. This tool reads the values from nvram and set those info to the wireless driver.
In our case nvram is getting updated properly but the wlconf fails to set the PSK value to the driver. That's why the AP is behaving as a non secured one.
kaustab
kaustab's picture
thanks a ton... I have
thanks a ton... I have started to look into the code will update you the proceedings.
Psypher246
Psypher246's picture
Hi all, this seem to be a
Hi all, this seem to be a problem for me too. it's November now, has anyone got a fix for this? Is WPA broken for everyone? is there a workaround?
thanks
Michael
Michael's picture
Any luck so far getting this
Any luck so far getting this to work?
Michael
Michael's picture
Any luck so far getting this to work or is Tomato and WPA2 a no go...
Psypher246
no, i've stopped caring, I am
no, i've stopped caring, I am selling my router due to no support available for tomato at all, ie internet does not work, wpa does not work, ssh does not work and no-one on the forum has helped at all to try and get it working. not very happy with the device either, the wireless signal strength is terrible and the fact you have to solder things to get a bricked router (which happens very easily) is not very enticing.
Should have gone with linksys
Michael
Michael's picture
The router is fine - try
The router is fine - try using dd-wrt - the wpa and wpa2 both work flawlessly.
Psypher246
Are you able to adjust the
Are you able to adjust the signal strength effectively? as the signal strength on netgear is PATHETIC! = 5M. Does everything work? Can you create a PPPOE connection from the router and the internet actually works? Can you ssh into the router?
if so then please provide me with step by step instructions on how to get ddwrt on this router, without bricking, currently running netgear firmware and NOTE this is the EU router. So not all firmware applies
achilles
achilles's picture
For downloading the DD-WRT firmware for WGR614L u can follow the following link :
For installing DD-WRT on the router u can go through the following link :
http://www.myopenrouter.com/article/10339/DD-WRT-for-NETGEAR-WGR614L-Ins...
Psypher246
and this will work on the EU
and this will work on the EU routers?
I'm really sceptical. i have a working router right now that I can sell, if i brick this due to incorrect firmware i'm screwed. it's a very expensive router in my country
achilles
achilles's picture
Unfortunately I have NA version ..so can't confirm this..... I  think it should otherwise we would have two builds available here ..one for EU and one for NA version ....
Psypher246
then i'm sorry but i can't
then i'm sorry but i can't flash anything until i have definite answer
achilles
achilles's picture
Psypher246 said:
That's understandable ..... BTW u can go through the following link ....
It has been said here that this firmware supports both NA and EU versuions .... so u can try this out ....
http://www.myopenrouter.com/download/10554/DD-WRT-v10509-Std-Small-Test-...
Psypher246
to be honest guys, i've
to be honest guys, i've actually already been burned and really cannot afford to end up with a bricked router that has no warranty. I appreciate that you guys have been helping today, this is the most, if any, response I have had from many many posts I have made on this forum in 2 months. And it's actually for those reasons I am just going to sell this router as is, with a working netgear firmware.
thanks anyways, good luck
kclee
kclee's picture
Does anybody know Netgear
Does anybody know Netgear router with WPA security, which is running under Tomato ?
Thanks in advance
KC LEE
