WGR614L 'standard' dd-wrt?
9 posts / 0 new
AaronR
Does anyone know if it's possible to run the 'Standard' edition of DD-WRT on the WGR614L router? There are some features that the micro and mini don't have that I need to use...
Brandon C
Not that I have seen. Only
Not that I have seen. Only the version available here.
twindragon6
The flash available is 4MB on
The flash available is 4MB on that. If you rebuild it you should be able to put it on the WGR614L, I'm not sure if you can do the same for the WGR614V8 flash though (4MB flash as well). It might require a separate build.
http://www.dd-wrt.com/wiki/index.php/WGR614_v8
http://www.dd-wrt.com/wiki/index.php/Supported_Devices#Netgear
SouvikGhosh
No, the standard build will
No, the standard build will not run on 614v8. You will require to modify some part of the BSP and the flash layout as well. Some nvram attributes also needs to be changed. Download the version available here - this version incorporates all the changes required to run the firmware on 614v8.
twindragon6
SouvikGhosh said:
Well Could you make a custom build that incorporates more of the features of the "Standard" version of the DD-WRT Firmware such as IPV6, SNMP, SAMBA/CIFS CLIENT, RFLOW, HTTPS Support for Web Management, and just drop the lame features too make it fit?
http://www.dd-wrt.com/wiki/index.php/What_is_DD-WRT%3F#File_Versions
SouvikGhosh
we will surely try it out and
we will surely try it out and let you know the proceedings..
twindragon6
SouvikGhosh said:
Sounds good, I look forward to the end result.Cool Below is a link to the latest source code...
svn co svn://svn.dd-wrt.com/DD-WRT
Brandon C
For some reason he link is
For some reason he link is bad. Can you fix?
twindragon6
BrandonC said:
Ok, to download SVN in Windows you have to install TortoiseSVN or an equivalent.
http://tortoisesvn.tigris.org/
